Project Thread - 924 Turbo Build. 1/18/2012
Update: Page 4, 6/14/2011
Build Thread.
Started July 3rd, 2010 (Still on going) when I blew a $0.75 o-ring on the feed line to the turbo...
Aaaand our coffee table...
Just taking stuff apart at this point.. no plan in mind..
Shot of the dash before starting removal:
45 minutes later, had a fantasy football draft so I couldn't finish pulling everything.
Wiring harness for blinkers, wipres, etc:
Center console wiring for boost gauge, fan speed, and oil pressure gauge:
Build Thread.
I swear it'll get better.. Just some foreplay right now...
Torque Tube to bellhousing
The lil' snail...
It's pretty crammed in there.
Nice Porsche wastegate.. Will be updated for a 1bar wastegate spring..
Shot of the suspension..
Finally out!
Had to drop the crossmember, then had to remove the sway bar, then had to drop the control arms from the rear..
Work bench/tire storage...
The lil' snail...
Finally out!
Pressure Plate
Clutch shots:
Coolant temp sensor for megasquirt, in OEM position...
Custom dist. block off plate. From the trigger wheel group buy...
Had a machine shop thread the injector slot at the back of the manifold to accept this GM air temp sensor
Rainman
wow, awesome fab work, this looks like an interesting and ambitious project. what are the specs on that new turbo?
also, your welds are beautiful....
will you remove the porsche writing from the back?
Nice stack of dime welds Flosho! What level of
boost/power are you aiming for? I'm excited to see
it come together, that cast iron block is so under-
appreciated when it comes to making power.
I'll edit the first post tonight with some details.
And just so everyone knows I am not the fabricator.. I only produce the money. But I'm sure the guy working on it will be thrilled with your comments
