Best Steering rack seal kit?
I did some searching but there seems to be limited info on this. My rack is leaking from the boots pretty badly. Luckily I caught it before the reservoir went dry. I usually have far better luck rebuilding my own stuff if parts and procedures are available than buying a rebuilt unit. Also my car has pretty low mileage so I would hate to get a re-sealed rack in worse mechanical condition that the one in my car.
I see rennbay has a kit, as does 944online. Anyone have experience with either? Who is more complete? What are they missing if anything?
Nick
Nick
Nick
Nick
The only thing I can recommend is that while you're in there, check the spring that controls the variable steering, if it's broken (which I've seen a few times) replace it with the closest spring you can find. You'll probably have to go to a specialty hardware store for that one. We have Tacoma Screw here, but I don't know what's around you. Also, grease the bearing that the steering shaft ends in... and if it falls apart, you're not exactly screwed, but the fix becomes interesting... if that happens, ask and I'll tell you how I fixed mine.
Thanks guys...sounds like it is going to be a fun repair. I wonder if the workshop manual covers rebuilding the rack, going to pull it out now and look. My guess is nope.
I went for a quick ride today and lost about 2oz of fluid. Boots are just filling up.
I have a quick steering rack question, sorry to hijack.
Are all 944/951 steering racks the same or were there changes over the years? Can I drop a rack from an early NA in my Turbo?
http://www.rennbay.com/psrsealkitfull.html
Just take your time, and it should go smoothly. WYAI, I would recommend replacing the rack mount bushings, if you've been leaking like that, they've been soaked and are probably pretty done. Replace all crush washers too. Also, its recommended to replace your resivoir too as it contains the PS filter.
Thanks...at this point I am basically trying to decide how long I want to tie up the car for. I still may bite the bullet and get a rack, not sure yet.
Reservoir is on my list for sure. Going to check all of the hoses as well. Also going to do mounts and boots.
I am not sure it makes sense but it seemed to blow out pretty suddenly. I did an oil change a few weeks ago, everything was dry, belly pan looked good. I went for a ride on memorial day and came home to a puddle in the driveway.
I went with the Rennbay kit for my 968. Very complete kit with only one O ring left over. The only problem I had when assembling is I had installed a seal backwards which caused a huge leak in the boot area. After talking with Travis at Rennbay I disassembled the rack again and installed a new seal correctly. NO LEAKS!!!!!!!!
I vote for Travis at Rennbay. Just got my parts from him to do the timing/balance belts, water pump, front engine seals, power steering pump kit and power steering rack kit. Travis is really knowledgeable and helpful. Very good instructions for the kit on Rennbay.
Unfortunately, I wasn't able to get my power steering rack apart and will have to return my kit to Travis. As an alternative, I am going with a cheap rebuilt rack from Autozone. I wish I could rebuild my existing rack.
I went with the Autozone first but only lasted 2 months till leaking like a sprinkler. I returned the Autozone rack for a full refund allthough I still kept my oe rack instead as my core. Rebiult it with the Rennbay kit and could'nt be happier.
Just rebuilt my spare power rack with the Rennbay seal kit..... Wife is happy and can park the beast in our driveway now.
The needle bearing on the bottom cam be punched out with a 1/4" drive 10mm deep socket in order to get a punch on the back side of the inner pinion shaft pressed-in seal.
+2 on Paying attention to the direction the wiper seals come out, go in.
Great product for sure.
