door handle lubricant
Old 07-03-2011, 07:42 PM
DSMblue
DSMblue's Avatar
Default door handle lubricant
I am in the process of replacing the door handles with 968 handles and wanted to find out from the board what type of lubricant I should use on the lock cylinder and other moving parts in the assembly. I have some Wurth spray lubricant, and was thinking about using that, but wasn't sure. Quick replies are appreciated so I can get the car back together and working.
Old 07-03-2011, 08:12 PM
Dimitri_Antoniou
4th Gear
Dimitri_Antoniou's Avatar
use a graphite based lube, it doesn't attract dust
Old 07-03-2011, 11:25 PM
nzporsche944s2
nzporsche944s2's Avatar
or a teflon dry glide lubricant. Goes on wet and dries.
Old 07-04-2011, 01:55 AM
Grandpa#3
Grandpa#3's Avatar
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
For ANY Lock Cylinder, you always use Lock Graphite bought in any Auto Parts Store. Teflon or White Silicone Lube for other moving parts.
Cheers,
Larry
Quick Reply: door handle lubricant
