Refinished Calipers and Rotor Hats using VHT Paint
Well, what started as "simply" a caliper repaint turned into a full blown bearing replacing, ball joint rebuilding, caster block replacing, new wheel buying, shopping/working spree. However, I thought I would share some pictures of the project that actually got me started, a month ago, when my car's tires were last on the ground.
My procedure was pretty simple:
A couple things I will do differently if I do it ever again:
Last but not least here are the pics. Unfortunately the last one is a bit blurry but you can see in the second to last how well they turned out. I'm very pleased, but then I bet including everything I spent at least 20 solid hours working on these so they better look alright!
- Quick Stripper bought at Autozone (two applications - DONT GET ON YOUR SKIN!!)
- Pressure washer
- Wire wheel and sandpaper to get last bits off and scuff the surface
- Air gun to get dust off then two cans of VHT caliper cleaner to get all contaminants off metal
- 5 coats gloss black VHT caliper paint
- 2 coats gloss clear VHT caliper paint
- Oven baked at 200 degrees for 1 hour
- Used dremel with sanding bit to sand Porsche logo back to metal
- Mount them up
- Beer
- Plug the brake line hole with something more than paper towel. The first two calipers leaked out the hole while I heated them and wrecked the paint on the back, so I re-did them (ugg), I hung the other two upside down so the leaking wouldn't get on the caliper
- Painted the rotor hats slightly overlapping the rotor braking surface, it burns off anyway and would have looked better
- Spent more time sanding the metal parts I didnt paint before painting (i.e. bolt heads, bracket, hard lines). I realized after painting I can't really make them perfect now without scratching the paint, oh well they will be covered in brake dust sooner than later!
- Sent them in for powder coating, this was way too much work to be worth it!!! Rewarding though
Late Porkchops
Nice
Nice.
When mine come off for seals etc I am going to do them too. My bearings are super solid right now so again I hate to mess with them. But sometime I have it down to put bearings on all 4 wheels and to put seals and scraper rings in all the calipers. Hopefully my pistons and bores are good.
How did you handle the PORSCHE lettering? It looks good too. I see it says Dremel - but about what grit? Flat or round?
Anybody used this brake caliper paint kit by G2 and sold by Paragon?
http://www.paragon-products.com/Prod...2Dkit&CartID=7
Thanks.
Thanks.
I used a bit that was like a little cylinder covered in about 80-120 grit sandpaper (not sure what it was), then I sanded by hand with 320 grit but it would have looked fine even without the hand sanding. Oh, and be sure to put 2 or 3 layers of tape around the lettering so you don't scuff the paint off those raised lines.
I can't speak from experience directly but I will say the reason I didn't get that was because I had read two many experiences where it was difficult to apply (maybe 1 out of every 3 I read or so). May have been operator error but I never saw a single post about the VHT spray messing up and I just didn't want to risk doing it wrong and having to redo it all over again! I am relying on my meticulous prep work and 200 degree baking to result in reliability, only time will tell though!
did you clear the PORSCHE lettering after sanding it? i feel that would look a little rusty after a while if it wasn't protected...
looks great, nice job! I was actually at a parts store today looking at paint but decided against it... maybe this winter...
Hmm, no I didn't... Why didn't I?!?! The calipers themselves are aluminum I believe (or something non-magnetic anyway) so I wasn't really worried about the logo, but the bolts and bleeders are steel. Fortunately I haven't actually hooked the brake lines up yet, so I am thinking I will take em down again and put clear on all 4 of them. It's a good idea regardless if it is aluminum, add that to my list I guess! Just when I think its done... haha.
good work...
Haha, ouch! Well after mulling it over I decided I won't be putting more clear on at least in spray form... Just afraid it won't stick well to the existing paint and I am too lazy/beaten down to wanna mask the whole thing again (I hate masking!). I am thinking maybe I could find some high temp clear brush-on paint somewhere and could apply it only to the bare metal parts. I will update the original thread if I go that route, otherwise I can just touch up the sanding every couple years.
sounds like a good plan. im sure you'd actually get by with just sanding every once in a while. actually kind of fun with how easy it is to dremel raised surfaces!
Late Porkchops
Thanks. I had NOT researched it as I was just on Paragon theother day and added the paint to my cart to save and to possibly have around later. I think I will be using the VHT as well.
It seemed as though I saw somewhere there was a shop doing these and the seals. I cant remember where - seemed like it was $600 or so for all four rebuilt and refinsihed. Beings I am a terrible painter I might should be looking harder.
But thanks for the input and the inspiration. Nice job again.
FWIW, I had good results with the G2 kit. We'll see on durability...
For the lettering, some 320 grit sandpaper wrapped around a piece of square tubing knocked the paint off quickly.
