clutch housing removal?
im swapping parts off my old motor to my fresh rebuilt motor but im having trouble releasing the fork which will allow me to slide the housing out. is there a special tool needed for this?
There is a pin that needs to slide out before you can remove the housing. I think it's pulled from the passenger side but I may be wrong, I did it with the engine out of the car so it was fairly obvious. The pin is threaded so you can thread a bolt into it and grab it.
there is 1 retaining bolt (that has a dbl nut on it)
after u remove the bolt, u'll need to either slide hammer the clutch fork pivot pin out, or use a long thin rod (<5mm diameter) from the other side. be careful not to damage the "stop"
wish i had a diagram to show u.....but dcauto's site is down for some reason
I just take a slave cylinder bolt and put it in the shaft to pull it out. I put a big *** washer on that bolt before screwing it in, then I use a pry bar on the bolt (the washer helps) to pull that shaft out.
