Parking lights working without a fuse....
Old 07-30-2011, 03:35 AM
potent951turbo
iPod Tamer
potent951turbo's Avatar
Default Parking lights working without a fuse....
I have been driving my 87' 944 the past several days and I'm trying to fix some of its quirks.
So initially the entire right side parking lights started popping the fuse as soon as you turned them on. After looking around for broken wires and corrosion and finding nothing I decided to give up and just live with it until another day. Now out of no where the whole right side lights up as soon as you turn the key on and it has no fuse in place! Is anyone familiar with the wiring or have the factory diagrams handy to figure out a likely area where the lights might have a problem and be able to pick up power without a fuse completing the circuit? My manuals are in SC and I would love to knock this problem out this weekend.
BTW....the car is completely stock and does not have any kind of aftermarket alarm wired in and never has just in case you thought of that.
Old 07-30-2011, 03:38 AM
flightline
flightline's Avatar
I have no idea what could be causing this but the workshop manuals as well as the wiring diagrams are available online:
http://www.mikepellegrini.com/porsche_manual.php
Edit: I occurs to me that you could just start pulling other fuses until they go off, that way you can figure out what system they may be shorted to.
Old 07-30-2011, 03:55 AM
flightline
flightline's Avatar
Does the turn signal lamp in the dash cluster light up? How about the parking lights indicator? It's fuse #41, 7.5A, right? Try removing fuse #32 and see if that turns it off.
Old 07-30-2011, 12:34 PM
ZW 944
ZW 944's Avatar
ground fault. try wiggling wires and connectors around untill you can get the light to go on and off based off moving the wire
I had a similar issue with my windows, found out it was a wire that had a chunk taken out of the rubber wire insulation, and that was contacting the chassis.
the problem wire is going to be a power wire too, if that helps any
Old 07-30-2011, 01:08 PM
potent951turbo
iPod Tamer
No the turn signal lamp and parking light indicators do not light up when I turn the key. Those operate just as they should when you turn the switch/turn signal. I will go outside shortly and start messing around, I forget which fuse it is but I think your right.
I will definitely try moving things around and see what I find.
Old 07-30-2011, 07:00 PM
teamking
teamking's Avatar
Try pulling relay G16 and fuse 37 as well.
Old 07-30-2011, 07:07 PM
teamking
teamking's Avatar
Why is that?
Old 07-30-2011, 08:22 PM
Rock
Lazer Beam Shooter
Rock's Avatar
Uhm.
Did you make sure that you dont have the turn signal stock engaged....
Quick Reply: Parking lights working without a fuse....
