Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 08-10-2011, 10:40 PM   #1
yorkee
User
Default Vertexauto rebuilt waterpump
Just got a rebuild waterpump from Vertexauto. Quality kinna questionable:
Click the image to open in full size.
It looks like dipped into a buck of paint. When I play around the screw on the blockoff plate, paint flakes fell off. There are paint dust in the odd corners and I am not sure if painting the roller is a good idea. That said, the roller bearing seems smooth, even though it is a bit hard. Is it the normal quality of a rebuild waterpump?
I start losting faith on Vertexsauto's quality because I received a set of Flennor belt from their belt and roller kit...
To remove this ad, register today or login if you already are registered!
yorkee is offline   Reply With Quote
Old 08-10-2011, 10:52 PM   #2
luftpirate
User
luftpirate's Avatar
Send a message via AIM to luftpirate
Are the studs dipped in paint also? If so get a dye on them or something, or more nightmares to come.
luftpirate is offline   Reply With Quote
Old 08-10-2011, 11:29 PM   #3
944Ross
944Ross's Avatar
I think the paint on the pulley is the most troubling. Unless it's a real high-performance enamel, I can't imagine it will last, and you'll end up with flakes in the teeth of the cogs and belt. I just don't imagine that is a good scenario.
'86 944/2 ..........'52 Ford F-1.......... '91 H-D FXRS-C
944Ross is offline   Reply With Quote
Old 08-11-2011, 01:39 AM   #4
RazrPorsche
RazrPorsche's Avatar
Location: Where the wind comes sweepin' down the plain...
I just had my waterpump replaced by PorscheDoc, Karl Wilen. I, too, ordered a rebuilt water pump from Vertex initially and Karl would not use it. He showed me all the paint everywhere, including the seal surfaces which is a no-no. I sent it back for a refund and used a rebuilt water pump that he recommended using because I trust Karl.
I would stay away from Vertex Auto for rebuilt water pumps and not use this one.
(In fairness, I will say that I've gotten a lot of other parts from Vertex and all were OEM and fine, so I don't have a problem using them for other stuff.)
RazrPorsche is offline   Reply With Quote
Old 08-11-2011, 12:23 PM   #5
carlege
Super User
carlege's Avatar
I have heard all the water pumps are rebuilt in house at vertex.
carlege is offline   Reply With Quote
Old 08-11-2011, 04:47 PM   #6
yorkee
User
This is retarded. Talk to their service department about the poor paint: "you are complaining about paint chip? buy a new unit."... " buy a spray can paint it yourself" were the responds. And they claim that paint on the roller has no ill affect on the belt.
As for the paint flakes and dust in the coolent in/outlet, their response is "what about it?" Are you mechanical inclined? because you are asking some funny questions." I am not as mechanical incline as them but I appreciated better manner.
Needness to say, Vortexauto will be out of my list.
That said, I got to give them some credit, the life-chat support has been very helpful. Thats what buy me to purchase from them in the first place.
Are there any reputable place I can buy rebuilt waterpump and belt kit without any trouble?
Old 08-11-2011, 04:53 PM   #7
carlege
Super User
carlege's Avatar
944 online carrys zimms rebuilt units that seem to have a very good reputation
Old 08-11-2011, 05:53 PM   #8
944_S_TYPE
User
944_S_TYPE's Avatar
Kevin Ketterer
944 online for $119.00 I have always had good service fron Ian. However it appears his roller is painted in the pic...
http://www.944online.com/cgi-bin/ASI...ercooling-9441
Pelicanparts ( I have used this one) $109.00
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
Or $95.00 at Zims.... two year warranty on rebuilt.
http://www.allzim.com/acatalog/944_N...ter_Pumps.html
944_S_TYPE is offline   Reply With Quote
Old 08-11-2011, 07:44 PM   #9
RazrPorsche
You definitely have to tell them ahead of time that you want a Contitech belt and NOT a Flennor belt. They will send the flennor automatically in the kit unless you make a point to tell them.
When you call Vertex, talk to Sid. He's the only one I've talked to there. He was very helpful to me and didn't give any crap about returning items that I wasn't happy with.
Old 08-11-2011, 07:56 PM   #10
yorkee
User
Thanks for all the info. Should've ask you guys where to buy stuff first
After seeing the 944online pic, is it normal that they paint over roller? I don't want to accuse Vertexsauto for poor parts if its how it supposed to be.
It doesn't make logical sense to me painting over roller...
Old 08-11-2011, 08:23 PM   #11
944_S_TYPE
User
944_S_TYPE's Avatar
Kevin Ketterer
If you are concerned about the Pump's paint job, Just strip it down, prep and repaint. Should you have to do that ...No, but since you already have it, might as well.... Or you can just clean the roller and mating flange...
Old 08-11-2011, 09:01 PM   #12
PorscheDoc
PorscheDoc's Avatar
Send a message via Yahoo to PorscheDoc
I've had two customers order pumps from vertex for me to install. They have both been crap. The first one the impeller was not pushed on all the way and bottomed out on the block. The 2nd one had the gasket surfaces painted, the impeller was completely corroded and merely painted over. I have refused install both times.
Doc Wilen
PCA/NASA Instructor
86 951: 5.3L v8
90 964 C4
My P-car blog:
RennsportKC Blog
Parts F/S:
PorscheDoc is offline   Reply With Quote
Old 08-11-2011, 09:29 PM   #13
944_S_TYPE
User
944_S_TYPE's Avatar
Kevin Ketterer
Quote:
Noted. Great information on here. Thats what makes this forum so good.
Old 08-11-2011, 10:03 PM   #14
zerMATT951
zerMATT951's Avatar
Matt Platts Matt Platts
My 924S and 944T both have Zims rebuilds... No issues probably put 75k miles on the 924S before I sold it, and the current owner is going on another 4 years since they bought it from me. I don't recall what the spray paint looked like when I got them, but I'll say they looked fine...
Matt P.
'86 944 Turbo
LR Super-53 (T04E 60-Trim Stg 3), Dual Port, Full 3" | M-Tune w/E85 @ 20 PSI | Late Offset M030 | LSD
'87 924S
Gone to a new home | '07 Avalanche 4x4 Family Hauler | '08 Volvo V50 T5 Wife's DD
zerMATT951 is offline   Reply With Quote
Old 08-12-2011, 12:51 AM   #15
RazrPorsche
See I told you! I was one of the 2 customers. Hi Karl!
Paid Advertisement
Tags
1987, 928, 944, flennor, porsche, problems, pump, quality, rebuild, rebuilt, remanufactured, rennlist, vertex, vertexauto, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
