Several tries to start..
Old 11-13-2011, 11:06 PM
PeteL
Got Nothin'
PeteL's Avatar
Default Several tries to start..
When cold, as in sitting idle over night or for a few hours, it takes my 86 na several tries to start.
First try...crank, no fire. Second try, same, maybe a sputter. Third try, sputter and die, fourth, start runs like crap, dies. Fifth try starts after extend cranking, sputters stays running, idle smooths out after twenty seconds. Once running, it goes like a scalded cat.
New fuel pump check valve, injectors, and fuel pressure regulator. All recently installed in an attempt to fix this issue.
It really feels like a fuel issue.
Old 11-14-2011, 01:40 AM
Paulyy
Professional Hoon
Paulyy's Avatar
put a fuel pressure gauge on the rail. if theres pressure when you're starting it, it could be the injectors or it's not a fuel issue.
look at spark issues.
cap + rotor
spark plugs
leads
coil
grounding could be bad on the coil.
Old 11-14-2011, 05:57 AM
PeteL
Got Nothin'
PeteL's Avatar
Cap, rotor, plugs are all new with rebuild. Wires are not that old. Injectors brand new.
Coil could use checking.
May also look at speed and reference sensors.
Old 11-15-2011, 06:47 AM
PeteL
Got Nothin'
PeteL's Avatar
Any votes for fuel pump, or ref sensor?
Old 11-15-2011, 08:03 AM
xsboost90
xsboost90's Avatar
i would say regulator but you said its new. Once i had this problem with my turbo, the vac. line to the regulator was pulled off and it was running super rich and at start up it would take a few tries then stutter real bad until it warmed up. Check vac to the regulator. Also make sure the TPS is closing all the way and the AFM is sweeping smoothly not catching.
Old 11-15-2011, 10:37 AM
PeteL
Got Nothin'
PeteL's Avatar
I will check all. The reg is new, vac lines are new as well with the rebuild, but I will trace that vac line to be sure it is connected. Fiddled with the TPS this weekend, clicks etc as it should.
Really feels like fuel. But I have to stop chasing the problem with parts.
Old 11-15-2011, 01:27 PM
wesmc3
wesmc3's Avatar
were you running fine and then had the problem start suddenly.
Old 11-15-2011, 04:53 PM
PeteL
Got Nothin'
PeteL's Avatar
I just got the car back from an engine rebuild, we had a rough idle after start, that would smooth out after 30 seconds or so...then, it seems all of the sudden, I started having this problem a few weeks after the car got back. Nothing comes to mind if something changed.
It seems like it doesn't have enough fuel to get started. It takes the same number of tries to start regardless of outside temp, etc.
When the car got back from the engine rebuild it fired right up.
Old 11-15-2011, 05:34 PM
MAGK944
MAGK944's Avatar
First place I would look for the cold idle problem is the dme temp switch or the O2 sensor. As to the cut out, do this check:
Remove the passenger floorboard and remove the dme from it without disconnecting it. Then try to start the car while tapping the dme.
If you noticed a difference it could be the power resistors in the dme detaching from the circuit board. Quite common and an easy fix.
Old 11-17-2011, 01:39 AM
ballysdad
ballysdad's Avatar
I vote dme temp switch and to make sure both vacuum lines are attatched. They come off and hard to notice because they sit just out of eye sight on top.
Old 11-17-2011, 03:02 AM
Sentinelist
Sentinelist's Avatar
(if it comes down to the ignition coil by chance, PM me as I just replaced a good OE coil and can't send the new one back)
Old 11-17-2011, 03:06 AM
Paulyy
Professional Hoon
Paulyy's Avatar
check for spark at the spark plugs. to rule out the spark.
Simple test. either pull a plug or find an old one that works and connect it to a lead from a spark plug. Crank and watch for a spark
Old 11-17-2011, 03:24 PM
PeteL
Got Nothin'
PeteL's Avatar
DME temp sensor is new. Replaced with rebuild, also reads same resistance as a spare. I assume that's the same as the Temp Switch. All vac lines were replaced with the rebuild, but will check them again.
Old 11-17-2011, 03:25 PM
PeteL
Got Nothin'
PeteL's Avatar
I have spark. The car starts, after several tries. Once the idle smooths out (30 seconds?) it runs like a scalded cat.
Old 11-17-2011, 03:26 PM
PeteL
Got Nothin'
PeteL's Avatar
It doesn't cut out. When the car will not start, it sputters and dies.
So far, has not stalled once running, what we have here is a car that is difficult to start.
Quick Reply: Several tries to start..
