944 S2 plastic oil sump pan ??
Old 12-04-2011, 03:00 PM
GSTEVE
GSTEVE's Avatar
Default 944 S2 plastic oil sump pan ??
I was Looking through some of my old mags and came across a December 1988 edition of Christophorus focusing on the 944S2.The article states that the S2 would be fitted with a plastic sump to save weight.Well I have an 1989 S2 cab with an alloy sump and I can honestly say I have never seen one yet.So has anybody out there got one ?????
Old 12-04-2011, 03:39 PM
V2Rocket
Rainman
V2Rocket's Avatar
cost of producing a plastic sump probably pretty high for such a limited number of cars; not many S2s were built. not to mention no (that i know of) differences between S2 and other model oil pans, which they may have had a surplus of Al ones.
itd be cool though.
Old 12-04-2011, 03:44 PM
944meister
944meister's Avatar
plastic sounds like a terrible material to use, i know the turbo cup and maybe also the firehawk series cars used magnesium sumps, maybe thats what they meant.
Old 12-04-2011, 07:37 PM
xsboost90
xsboost90's Avatar
never seen one or heard of it. Probl got scrapped.
Old 12-04-2011, 08:52 PM
ramius665
ramius665's Avatar
And interesting idea but I wouldn't run one. I've seen a couple of 944s and a 928 bottom out hard and scrape the oil pan. The 928 wound up tearing a hole in its oil pan. Plastic just seems like it would exacerbate the problem.
Old 12-04-2011, 09:32 PM
chrenan
chrenan's Avatar
They probably meant the factory plastic oil pan baffle (internal) that all the late cars have.
Old 12-04-2011, 10:43 PM
krystar
krystar's Avatar
yea but even a titanium oil pan would still crack if u bottomed out on it. plastic might actually help if the material bends instead of cracks.
Old 12-05-2011, 02:27 PM
944meister
944meister's Avatar
even if the plastic got more maluable with heat, i doubt the plastic would'nt crack with a good wack. you also have to consider that the oil pan material must be able to dissipate heat, which magnesium and aluminum do very well, and are far more structurally rigid.
Old 12-10-2011, 11:34 AM
Nobbi
Nobbi's Avatar
They are original Porsche ! With the plastic pan you have 0,5 liters of engine oil more available to cool them down.See the PET.
Nobbi
Old 12-10-2011, 11:56 AM
namasgt
namasgt's Avatar
Wow, something like that was made for the 928 too (out of plastic). But we only know about one since it showed up on ebay with a Porsche part number for 600 bucks. Obviously they knew about the oiling issue with rod bearing failures.
Here is the link
https://rennlist.com/forums/928-foru...lies-heel.html
Old 12-12-2011, 06:33 PM
nzporsche944s2
nzporsche944s2's Avatar
Nobbi
Nobbi - where is that part number? On the PET i can only see one part number available for the S2 motor (M44.41). PN# 944 101 204 00??
Old 12-12-2011, 07:04 PM
Dawgz83948
Dawgz83948's Avatar
Typical Stupid German idea. Can anyone tell me how good the heat transfer is on plastic? If not good at all was you're answer, you would be right. Why the fins on the plastic then???
Old 12-12-2011, 07:25 PM
Fara
Fara's Avatar
It's the latest development in fictional materials! Heat conductive plastics!
It's flexible and has a shape memory too.
Alas, if only I could create this plastic. I would be rich!
Old 02-10-2013, 07:01 PM
Arominus
Arominus's Avatar
Old thread bump for knowledge. My 88 944S has a similar pan on it from the factory, it has the plastic baffle and the integrated scraper. I have a 968 pan next to it the plastic baffle and the scraper has a slightly different profile (more bumps towards/at the sump). the part number on the 968 pan ends in 0R same as the s2 pan. My 944S pan ends in 8R
I thought only the turbo, S2 and 68 got the scrapper and baffle? or did all late (85.5+) 944's get them?
Old 02-10-2013, 08:17 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
300 hour oil pan for a 5,000 hour car.
grrrreeaattt.
Quick Reply: 944 S2 plastic oil sump pan ??
