Balance Shaft Belt Dangers?
Old 05-01-2023, 11:15 PM
TurrFinn
TurrFinn's Avatar
Default Balance Shaft Belt Dangers?
Is there any danger long term to not running a balance shaft. I understand racers will delete them. My lower balance shaft is sticky and I need to address it but I can't as of now so I don't have a balance shaft belt and I just want be sure I won't hurt anything.
Thanks,
TurrFinn
Old 05-02-2023, 12:37 AM
tempest411
tempest411's Avatar
Thanks,
TurrFinn
The increased vibration is known to cause cracks in the oil pickup tube and the fuel injector manifold. It's very bad for either to fail!
931guru (05-02-2023)
Old 05-02-2023, 10:07 AM
TurrFinn
TurrFinn's Avatar
I read about the oil pick up. I don't know much about the balence shafts but my lower one is sticky and I believe it is my reason for a belt whine. I don't know what to do to fix it, any ideas?
Old 05-02-2023, 11:55 AM
Nowanker
Nowanker's Avatar
Location: Formerly the DPRK, now seeking political asylum in Oregon
I can vouch for that personally....
Old 05-03-2023, 04:08 AM
tempest411
tempest411's Avatar
The balance shaft is 'sticky'? It's easy enough to pull off the cover and shaft and have a look. May as well get new bearings & seals while you're at it.
Tiger03447 (05-04-2023)
Quick Reply: Balance Shaft Belt Dangers?
