N/A Horsepower
Old 03-05-2012, 11:59 PM
xsbank
xsbank's Avatar
Default N/A Horsepower
Porsche Canada says the N/A has 150 hp with a cat and 163 hp without. Hand me my sawzall, will you?
Old 03-06-2012, 12:04 AM
MAGK944
MAGK944's Avatar
That is true, but the cars built without the cat (ROW) also had 10.6cr pistons, a reprogrammed dme and ran on higher octane fuel.
Old 03-06-2012, 03:33 AM
rgs944
rgs944's Avatar
Getting rid of an old cat that may be plugged might not be a bad idea.
Old 03-06-2012, 09:41 AM
nasty9er
nasty9er's Avatar
i pulled the cat on my 924s when i did the headers. (the cat was only a year old) and i did notice improvement in topend speed but you do lose lowend torque(no back pressure). when inspection time came around i had to put the old setup back in and ended liking it more with the cat in so now my plan is to splice in a hiflow racing cat into my delete pipe. my 2 cent
Old 03-06-2012, 09:57 PM
Geo
Geo's Avatar
You changed two things at once: header and removed cat.
Reducing backpressure does not lower the torque. The header moved the powerband.
Reducing backpressure lowering torque is an old wives tale.
Old 03-06-2012, 09:58 PM
Geo
Geo's Avatar
This
Old 03-06-2012, 10:05 PM
V2Rocket
Rainman
V2Rocket's Avatar
The internet is full of confusion between "backpressure" and "exhaust gas velocity"...
That said, I just found a 944 header collector pipe cut off after the O2 sensor. I'll let you all know if it feels any faster, or just louder
Old 03-06-2012, 10:08 PM
nasty9er
nasty9er's Avatar
Your 10,023 posts trump my 345. I stand corrected.
altered power band makes sense
Old 03-06-2012, 10:31 PM
pcarfan944
pcarfan944's Avatar
Does removing the cat result in an increase in exhaust noise? I would gladly remove my cat as long as the engine/exhaust tone remained the same.
And, to set this straight, simply placing a straight pipe where the cat once was WILL NOT result in a loss of low end torque? In the eight years I've been here, I've never seen a clear cut answer to that question.
Old 03-06-2012, 10:49 PM
Geo
Geo's Avatar
Boy howdy.
Old 03-06-2012, 10:50 PM
nasty9er
nasty9er's Avatar
Mine is a louder with out the cat, but i do have an after market exhaust so it might be less noticeable in your case.
but thats just what i have experienced
Old 03-06-2012, 10:51 PM
Geo
Geo's Avatar
Post counts are BS. Don't rate anyone on that. Same for time on a board. Through the years I've seen so much incorrect "common knowledge" here it's funny.
Old 03-06-2012, 10:54 PM
Geo
Geo's Avatar
Removing the cat does make most cars louder. But not more powerful.
The late Sport Compact Car magazine (when its editors were automotive engineers - I know a few of them) did a great dyno test with and without cat on a S13 240SX (similar engine to the 944). No change in power, and a loss of 1 ft/ft of torque w/o the cat and that is well within the degree of error on a chassis dyno.
Now, and old cat may cause problems, but a good cat (aftermarket is fine), especially a high flow cat (as most modern cats are), will NOT hurt performance.
Old 03-06-2012, 10:57 PM
nasty9er
nasty9er's Avatar
it was a joke
Honestly i hate old wives and there story's.
Old 03-07-2012, 12:43 AM
white924s
white924s's Avatar
I have stock headers, no cat, and a Dansk muffler. This setup is a little bit louder than stock, but not much.
By comparison, before this I had an MSDS header, hi-flow cat, magnaflow muffler, and 3" tubes to connect it all) and it was substantially louder than stock.
Quick Reply: N/A Horsepower
