Reference Speed Sensor Removal Gone Wrong
#34
So im in the middle of it now, COVERED in grease :P I need to fix these oil leaks. Took off the starter and was able to the can out, got the new sensor in and I am just looking for the pic that shows which is DG and which is BG :P. Will post pics later.
#35
Ok so I got to drive it home today Its nice having a car again.
While trying the crush the cup I ended up making it just small enough to where it would fall out of reach of the hole... AWESOME!!!! So long story short I pulled the starter and gently hand cranked the crankshaft pulley until the cup eventually fell out. I cleaned up the starter and inspection plate while I had it off, all this caked on oil is making my eye twitch due to my project OCD.
I need to check the sensor on an oscilloscope tomorrow, but it feels like I don't have the power that I used to.... And I even had my butt dyno calibrated yesterday so we shall see what I find tomorrow.
Photodump time...
Photodump time...
#37
So the car runs great, I noticed I have a little bit less power than I used to though, Going to take the sensor back out and double check the clearance if the pattern on the oscilloscope looks anything but perfect.
#38
#39
So lack of power ended up being a mixture of water under the distributor cap (wtf?) and alot of moisture on the coil. Dried everything out and it ran like a dream, still have to do a TON of general maintenance to it though.
#40
Proprietoristicly Refined
Great to hear!
There is a seal between the distributer cap and cam gear sheild/cover...
In picture cut out the center part-should not be there.
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
The moisture could also be thrown up from a leaky waterpump seal.
GL
John
GL
John
