Reference Speed Sensor Removal Gone Wrong
Hey everyone, So I just picked up an 87' 944 this last Monday. It ran great up until yesterday morning, turns out the reference speed sensor died. Upon removing it today I realized that I am pretty much screwed unless somebody has a better idea for removing the casing that is stuck in the holder :P.
Also, I soaked this thing in Aerokroil for a day or 2 so don't freak out. Ouh and sorry for the pictures, camera didn't want to focus.
Proprietoristicly Refined
Not uncommon to have the reference sensor break off in the sensor bracket.
You can try for a couple of hours ( or days) to unbolt the sensor bracket from the engine.
The passenger side bolt usually comes out with a lot of work.
The drivers side bolt is next to impossible to get out. Some have removed the intake and failed.
Work on it for awhile.
Then I suggest you carefully break the sensor bracket in pieces and get a new bracket.
Here is one mans story (of many):
https://rennlist.com/forums/924-931-...nsor-bolt.html
GL & welcome,
John
GL & welcome,
John
Cool cool, thanks for the help. I have been looking around for diagrams online to find out how I could gain access to the ring gear from the top so I can set the 0.8mm gap, cant seem to find anything helpful though.
Also, tada? http://www.partstrain.com/store/deta...8107496388rese
AH,
A very keen eye. The interchange sensors with the metal wrapped bottom, I consider the best. If you find all black plastic, they are slightly cheaper.
When you get everything apart, clean the FW flywheel sensor studs of oil and dirt.
I did notice on your first picture, if you look closely, you will notice that the washers behind the reference sensor bolts are different (thickness).
What this could mean is that someone, maybe recently, worked on the sensor bracket and got the bolts out. Maybe on a clutch job.
So...try very hard to get the 2 bolts out. Then get drastic.
Good luck.
John
Good luck.
John
If you got the right size screw/bolt you could go down into the casing and then pull it out. If that didn't work maybe drill through the bottom of the casting and run a thick bolt/screw through it.
How thick is that aluminum casing? This is probably a long shot but what about lightly threading it with a tap and screwing a bolt into it and pulling on that. I would assume it's to thin to do that though.
It seems that it would be easier to just remove the sensor mount and work on it off the car. It would be alot less painful for your back at least lol
I wouldn't recommend spending too much time trying to get those bolts out, the chisel trick will pay for itself in skin. Apply liberal anti-seize after to bolts, the sensors, etc. I used a rotary tool to sand out the corrosion from the bracket and it also had the effect of 'widening' it a bit, but the o-rings still grab good.
Paragon carries a lot of parts for your car:
http://www.paragon-products.com/Pors...61.210.002.htm
GL
John
tada et tu
GL
John
GL
John
BMW Bosch Number W0133-1613778
Porsche Bosch Number W0133-1603778
Numbers are pretty damn close lol
Spark plug or some sort of extractor like this might work.
http://www.irwin.com/tools/screw-bol...-522532-series
I bought a set to remove a spark plug that snapped and left the threaded part in the cylinder head, worked like a charm.
So the barrel sure didn't want to come out with the rest of the sensor, nor any of the ways that I was trying to coax it out with... but oh boy! It sure wanted to go in even farther! Somebody.... Put a ****in bullet through my brain... Normally this wouldn't be such a big deal for me but atm this is my ONLY car... and I work 24 miles away at a job that makes me want to go postal...
Is the piece magnetic? If so, you might be able to take a wand and pull it up thru the hole. Otherwise you might be able to fish it out through the clutch inspection port.
Specialty long needle nose? I haven't had the pleasure of working through this problem before.
There are also those little picker tools (for PC), where, it looks like a pen, and you depress the plunger, and 3 little arms come out, and when released, close down. Imagine using this in reverse. Put it down the middle, depress plunger, and then draw it up to try and bring everything up.
Because I'm not so smart, what if you just jammed a dowel down there? Where does that go? clutch area? Will it just sit at the bottom? Could you intercept it from the clutch inspection hole?
