Get rid of the 944... or not? - what do you guys suggest?
No, not Mosquito!
Hey everyone, long time no see! Some of you may be familiar with my 944 - an early (83) going through the late interior conversion. I'm sorry I haven't updated my thread on here in such a long time, but I just haven't had time to even log on RL very often.
I've had to put the car on the back-burner due to work. I can't see myself having any time in the near future to finish working on it, and quite frankly, I'm sick of housing it in the workshop. It's just taking up space. At the same time, I love the car and have years of slow-moving work into it. I either want it gone, or I'm going to keep it forever and eventually have it complete.
So this is just a 'feeler' thread on what to do. What you guys may suggest I do with it. So, here I go.. on with some information...
I'll list a few things I feel need to be mentioned about the car off the top of my head:
The body:
-The body work is all complete - it just needs a paintjob. The car is straight and true. Not a dent or crease. I also deleted the rubber bumperettes up front, deleted the rear antennae, and made the nose panel removable. I also deleted that wretched center reflector and relocated the license plate properly. The rear bumper is missing - I never replaced it - the previous owner removed it for some reason and I never acquired it.
Engine:
Engine is currently out of the car. I cleaned it up but have not taken it apart. It runs just fine, I was just doing a beauty job. The motor mounts were shot, so those need to be replaced immediately before the engine can be set back into the car. Needs a new timing belt and all new accessory belts. Needs new water and oil pump. Needs rear main seal to go along with the new clutch job. The bracket for the Speed/Ref sensors is also broken, but can be easily replaced.
Exterior Parts:
-New Koni shocks up front, paint refinished on the rear Konis.From the M474 package.
-Torque tube resprayed silver
-Transmission resprayed silver
-new clutch disc
-refinished flywheel
-ceramic coated pressure plate (for looks and to keep rust away)
-complete late offset conversion. All aluminum parts sandblasted, refinished, and shot with automotive clearcoat to preserve the look.
-powdercoated silver metal flake 16" 928 wheels with Toyo Proxies
Interior Parts:
-Reupholstered front seats in champagne leather
-968 dashboard
-968 center console
-968 door panels
-968 rear seat and dual folding backrest
-late style climate control system and all parts. Early system deleted.
-Firewall modified to fit late climate control system
Everything else:
-Manual steering rack needs a new boot
-No gauges, I was going to do a custom job
-No carpet, I always meant to buy a new set. Never happened.
-I have every nut and bolt in ziplock bags labelled with where they came from and where they go. I tried to be as organized as possible.
-If I didn't mention other parts, because obviously I'm leaving off a million, those are either parts I haven't refinished, fixed, and are probably sitting in storage. I have most every part for this car except weather stripping.
My final thoughts:
I feel like this car should be parted out due to the amount of work that is left for it to be road worthy once again. If it were to be completed, it would probably be better off as an auto-x car. The major work left would be wiring and paint. Everything else is easy I would say.
What would you guys do? The finished parts I have are quite beautiful and are probably worth in pieces more than what I could get for the car as a whole.
I'm open to suggestions. Here's a gallery of photos to give you guys an idea of my project. Towards the end of the album is how the car currently sits. I don't have any pictures of the transmission painted or the clutch bellhousing, but I can do that tomorrow if anyone wonders how they look.
View the pictures here: http://gallery.me.com/california500#...hite&view=grid
Cheers!
The body:
Engine:
Exterior Parts:
-new clutch disc
Interior Parts:
-968 dashboard
-968 center console
-968 door panels
Everything else:
My final thoughts:
Cheers!
Today I got
My Custom Title
My Custom Title
Odd Posts
You will regret getting rid of it. My secret on my 5 year TR6 rebuilt is to plan to do a small thing now and again just to keep the project going. That will prevent the negative thoughts of sale from popping up too much.
When I got rid of a perpetual project car I was never going to finish I felt a great deal of relief. I was also pleased that the people who got the engine and chassis were excited to be moving forward. What really got me was that even if I finished it, I was not likely to want to drive that car much anymore. Not only because it was a restored car that might get damaged but because my interests had changed. Unless I'd won the lotto and could fix it up for my extensive car collection there was just no point.
-Joel.
-Joel.
No, not Mosquito!
Thanks for all your input so far. I realize there may be a moment of grief, but I also understand what Joel is saying - which is the direction I'm most leaning.
Rainman
The motor mounts were shot. Needs a new timing belt and all new accessory belts. Needs new water and oil pump. Needs rear main seal to go along with the new clutch job. The bracket for the Speed/Ref sensors is also broken, but can be easily replaced.
Everything else:
Everything else:
I have a 97k mile 951 oil pump I don't need, but this guy is selling a factory new oil pump for cheap (https://rennlist.com/forums/944-turb...951-parts.html).
...I felt a great deal of relief.....
I had a project motorcycle in my garage, completely apart and in boxes scattered all around, for over 10 years. At various times over the years I'd hit it and get part of it done. But I came to realize I probably didn't really want it. I decided it was worthless in pieces, so I hit it hard and finished it up (to a low standard, admittedly) and rode it a few times. Put it on Craigslist, sold it two days later. I didn't regret it for a minute. In fact, it made me realize a camp trailer I had wasn't worth keeping either, so I sold that, too. It's an incredible feeling to not have "stuff" taking up space, time, and money, if they aren't getting used.
No, not Mosquito!
Thanks for everyone's input/stories. I need to spend some special time with her to see if sparks fly once again...
No, not Mosquito!
I spent a few hours with her yesterday and re-cleaned some of my restored parts. I think all hope is not lost... I've still got that lovin' feelin...
