stripped axel bolts
stripped axel bolts
Im in the process of trying to remove the transmission on a 1986 944 and it looks like the 12 point internals were impacted in, so the heads of em are toast. Any suggestions on what to do now?
Edtay
Edtay
Rainman
you can try using a slightly larger (probably SAE) hex or cheesehead if you can find one and hammer it in.
alternatively you can find these screw extractor things that have a backwards twist on them, hammer them in and then use a wrench to loosen.
Axle bolts
What i managed to do was use a pair of decent size vice-grips and take them out. i had about 6 that were all rusty and stripped and with a little force came right out with the vice-grips
-Nate
-Nate
SeaCay (09-01-2021)
Grind them off from the side of the head. There is a piece of metal that connects two bolts so if you are careful you won't need to replace the axles, just the spacers. Done this about 100 times.
I always go straight to the ez-outs from Sears. I've never had luck using the cheesehead bits or vise-grips. Just tap the ez-out on and they come right off with a wrench or socket.
I did this a couple years ago and it worked fine - just slow. I only had 1 that was stripped, the rest were fine. I still have the bolt on my bookshelf in my office! Good Luck.
