944 s2 headlight lens
Old 08-06-2012, 03:19 PM
mojieboy
mojieboy's Avatar
Default 944 s2 headlight lens
Hi All,
Just a quick query for you all.
One of the lenses on the pop up headlights has disappeared on my 944 s2.. (i guess it's either fallen off somewhere or cracked/smashed from a stone and then fallen off). Anyways, my question is this...
Is it possible to simply replace the lens or do I need a new a whole new headlight... I hope I can just get a new lens and fit it back on...??
If I can replace just the lens, how does it fit on / secure in place..?
Are all lenses the same across all 944's? I know that the assemblies are different on the turbo and s2 models but I'd guess the lenses are standard across all 1983-1991 models?
Any advice greatfully received!
Mike,
Old 08-06-2012, 03:45 PM
V2Rocket
Rainman
V2Rocket's Avatar
You can buy a replacement at any local auto store. The lenses are interchangeable between years, and are held in place with 3 screws around the edge of the glass (you have to remove the black plastic shroud first of course).
Old 08-06-2012, 09:01 PM
djantlive
djantlive's Avatar
My local store sells the whole light with housing and bulb in a sealed package.
Old 08-07-2012, 04:27 PM
dontnow
dontnow's Avatar
The headlamps are a sealed beam unless they have been coverted to GT style.
http://www.napaonline.com/Catalog/Ca...4BL_0277537817
Old 08-07-2012, 04:28 PM
Jrboulder
Jrboulder's Avatar
This might be a good time to upgrade to H4 headlamps.
Quick Reply: 944 s2 headlight lens
