What would you all do to delete the cat on a 951?
I'm looking to remove the catalytic converter on my 951 soon. For, ermm, off road purposes. Tips and suggestions on what specific pipe to replace it with? Didn't find a lot in the search- thanks.
Hey Chris,
What I did was to weld a straight pipe from the factory cat all the way through. Then I bought a high flow cat and 2 band clamps. Therefore, when I have a track event, I substitute the cat for a straight pipe and when I have to pass emissions, in goes the cat.
http://www.pelicanparts.com/cgi-bin/...0%281986-88%29
This is what I'm going to do..that way I can keep the Cat in tact..you know, in case the lawman gives me any trouble.
I would by a test pipe from Lindsey, then buy one from Fabspeed, then buy one from SFR, then I'd cut out the old cat, weld in a pipe that's 2.5" diameter, and, finally, sell the 3 test pipes on Rennlist!
Is the OE cat welded on there or can I unbolt the thing and DIY with a wrench? I haven't jacked it up to take a look at this specifically.
The cat is welded in place. The pipe is double-wall in front of the cat - down pipe and S bend - for better insulation. There's also a secondary, tiny cat on the wastegate bypass pipe.
What we used to do in my younger years was remove the cat, split in half and gut it, then weld a pipe through the center. Basically just put the shell over a length of pipe. Looked just like it had a Cat for the visual inspection and oddly enough, it still passed the 'sniffer test'.
I've heard of that method- that test pipe I bought for my old Passat looked identical to the OE cat for that purpose. What was nice about it was, IT BOLTED ON. I'm not jazzed about this welding malarkey. Especially since I've had to get my indy to spot weld a couple leaks in the system already.
I believe some of the cats we did had bolt on flanges welded to them which we duplicated when we put in dummy cat. No worry of leaks because shell was simply welded over the pipe.
I think I like the idea of using band clamps. Have an exhaust shop expand the pipe(s) to create a male/female joint and wrap a stainless steel band clamp around the joint.
WRONGLY ACCUSED!
Received 3,397 Likes
But in all seriousness, is there any benefit to welding in the 2.5 inch pipe inside the cat? Can't you just hollow it out?
