Fire Extinguisher Options
Old 08-17-2012, 06:33 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Default Fire Extinguisher Options
Looking for fire extinguisher and mounting suggestions for a 944 street car. What are folks using these days?
Old 08-17-2012, 06:44 PM
jtsporsche
jtsporsche's Avatar
I have a redline kit. Very clean look and cheap. Though I just got a standard chemical extinguisher, not a halotron gas unit.
Old 08-17-2012, 07:48 PM
HICKS
HICKS's Avatar
Rennline with HalGuard. http://www.rennline.com/Safety/products/801/
Old 08-17-2012, 08:25 PM
s14kev
s14kev's Avatar
Brey Krause mount / Safecraft Halon.
Old 08-17-2012, 09:13 PM
J Berk
J Berk's Avatar
Stable energies makes a great mount!
Old 08-17-2012, 09:35 PM
jpk
jpk's Avatar
I took a standard $20 dry chem from home depot (First Alert) and ordered a metal bracket for it instead of the plastic one that comes with it. (First Alert part # FEBRA2-6 for the bracket)
A bit of aluminum strap riveted to the bracket let me hang it from the 6mm bolt on the side of the console. The aluminum just slips up between the carpet and the side of the console. I put a couple of short self-tapping screws at the bottom of the bracket which really just go into the carpet to keep it level.
With the way this is oriented with the clamp, I can reach over from the drivers seat with my right hand, grab the extinguisher and release the latch with my thumb; all in one quick, smooth motion.
Old 08-17-2012, 10:18 PM
J Berk
J Berk's Avatar
Dry chem is better than nothing but I would suggest springing for the modern equivalent to halon... Which I think is halatron
no mess!
Old 08-18-2012, 02:58 PM
thirdgenbird
thirdgenbird's Avatar
I've got a halguard as well.
Old 08-18-2012, 05:46 PM
ditch68
ditch68's Avatar
I have a dry chem as well, it is white and marketed as a "recreational" variant for auto and motorhome use. I have it mounted crosswise between my seats off the harness bar on the 4 point roll bar, accessible, but out of the way.
I'll do a pic if anyone wants one.
Jeff
Old 08-18-2012, 06:15 PM
thirdgenbird
Jeff
I wouldn't mind hearing more about the extinguisher itself. Was it a lot cheaper than the h3r? I don't regret buying a halguard for my Porsche but I wouldn't mind a cheaper option for my ford bronco dd.
Here is my mount btw:
Old 08-18-2012, 06:53 PM
ditch68
ditch68's Avatar
Here it is. Made by "First Alert", got it at the local Ace Hardware - $17.00 and change. I'll spring for Halon at some point, but this was cheap. Better than nothing, I say.
Came with a cheap plastic bracket and strap, I replaced the strap with a nylon one until I source a better bracket.
Jeff
Old 08-18-2012, 11:12 PM
xsbank
xsbank's Avatar
If you hit something solid, that extinguisher will become a projectile...
Old 08-19-2012, 12:13 AM
ditch68
ditch68's Avatar
How will this one do so more than any other shown on this thread? They all, including this one, have a retention strap and a solid mounting.
It does not move in it's mount. The retention strap is not just sitting there, it is buckled. It's not there to get at quickly as much as just being there and reachable from either seat.
I may move it to the passenger side of the tunnel like jpk did, haven't decided yet. It is also behind the 4 point harnesses. I also may just move it toward the passenger side partly behind that seat.
Jeff
Old 08-19-2012, 12:31 AM
thirdgenbird
it is the cheap plastic bracket that would concern me. mine has two steel straps that are bolted to a significant aluminum plate. its hard to tell from the picture, but it looks like the bracket may break with enough force.
Old 08-19-2012, 12:36 AM
ditch68
ditch68's Avatar
I see your point(s).
I just went online and found a steel bracket for it made by the manufacturer, just like the one jpk has.
Better safe than sorry.
Jeff
Quick Reply: Fire Extinguisher Options
