Tight Silicone Hoses - How to get on?
Hi all,
I have the LR silicone cooling hose kit. But it is fighting me really bad at the heater core connections. I sprayed some lubricant on the fittings and on the inside of the hose. I got the upper, larger hose on with a lot of fighting, but the lower hose refuses to go on.
Before I cut up my hand any more trying to do this, are there any other tricks I can try? I think the lower hose is binding up on the upper hose, even with the lubricant. It's almost like there's no room here at all for both hoses. Too thick or something.
I have the clamps off for now but... any tips would be awesome.
Better than WD40? I can give that a go. It still seems like the outer diameter of the hoses might be too big. Is it possible I have the wrong ends on?
Late Porkchops
Summit Racing probably has the Aeroquip or Earls hose lube. I have used the Earls with good results and I have ssen the Aeroquip work well too.
Was a bit easier today after removing the waterpipe over the exhaust. Gave my hand a little more room. Also, starting from the top and then pulling down seemed to work as it helped prevent binding on the upper silicone pipe.
Both on there now and seem pretty tight. Been installing other lindsey hoses as well. They're a lot harder to get on, but lots of wd40 helps.
You're right about the residue helping pipes slide off. This happened a couple times during clamping. Or sometimes the clamps themselves would slide off. Bet rubbing alcohol works a lot better and a bit more temporary. I'll have to try that. Is it bad for the silicone though?
You ever get that sinking feeling wondering if you're going to have leaks all over?
Late Porkchops
Administrator - "Tyson"
