Bolt-on parallel flow AC condenser
Old 02-17-2013, 03:38 PM
  #46
gregeast
gregeast's Avatar
My car's gonna be so cool...
Old 02-21-2013, 03:56 PM
  #47
docwyte
docwyte's Avatar
PM Sent. Wish I'd seen this about a month ago when I still had the car in the shop...
Old 09-07-2013, 03:20 AM
  #48
Gawernator
Gawernator's Avatar
Spencer..? Will the condenser be shipping? ......
Old 02-18-2014, 11:45 AM
  #49
ChrisRL
ChrisRL's Avatar
Spencer, thanks for the steer. Yes, I'd definitely be interested!
Cheers
Chris
Old 02-18-2014, 01:34 PM
  #50
bebbetufs
bebbetufs's Avatar
I only need the AC about twice a year up here in Norway, but I want to keep the system for the long trips I'm planning trough Europe.
Can I choose a smaller condencer or won't it work with the rest of the system? I would like to make room for an rx7 oil cooler below it.
Old 02-18-2014, 02:11 PM
  #51
V2Rocket
Rainman
V2Rocket's Avatar
There is a condenser that should be able to fit an RX7 cooler below it...I don't have an RX7 piece anymore to measure, can you check the width? Should be OK.
Old 02-18-2014, 05:09 PM
  #52
bebbetufs
bebbetufs's Avatar
The RX7 cooler is 120mm tall. Perhaps you could offer that as an option for those interested in tracking their cars?
Come to think of it will probably be more expensive for me to ship the parts across the pond than it will be to fab up something over here. If not I'll get back to you.
Old 08-07-2015, 02:06 PM
  #53
Wmford
Wmford's Avatar
Default Drop me a line
Hi, drop me a line and where to ship my old condenser for you to convert.
Thank you
Will Ford
714-366-3773
Originally Posted by V2Rocket_aka944
Hi all,
I am posting this to gauge interest for the 944 owners who want to keep AC on their cars but have been forced to convert to R134a. The stock AC condenser is a fine unit but designed for R12 instead of R134a so doesn't work quite so efficiently. There is also the ~20-30 years of rocks and birds stuck in the fins on the outside, and dirt and slime on the inside reducing cooling efficiency.
A stock replacement for the AC condenser for a late car is $400, early is NLA. There is a made-to-fit serpentine style condenser available for the 944 but it runs around $500.
Modern cars with R134a from the factory use a parallel-flow type of condenser - rather than a tube-and-fin style the gas flows into the end tanks and makes several passes across the heat exchange surface before being expelled as a liquid. More distance to travel through the condenser means more time to cool, and the passages are designed with R134a in mind.
I have modified an aftermarket parallel flow condenser to bolt-up to a 944 using factory bracketry. It worked so well for my customer's 944S that I am offering this as a service to Rennlisters. Send me your factory condenser and I will send you back a bolt-on parallel-flow replacement - I need the factory piece for its bracketry. I am offering this at $325 including parts, my time, and return shipping. I can build one for you and you send me your old ones afterwards on an exchange basis as well.
It should be noted that 2 AC lines will need to be modified and re-made to make this work. The compressor to condenser line needs to be lengthened and a different fitting attached; and the condenser to dryer line needs a few more inches and a different fitting as well. About $375 total if you want me to make the lines for you as well, or I can give you dimensions to do yourself.
If you would be interested in this, let me know here or PM me.
Old 06-16-2016, 06:58 AM
  #54
The_Chemist
The_Chemist's Avatar
PM sent.
Old 08-23-2016, 10:44 PM
  #55
zeusrotty
zeusrotty's Avatar
Is he still doing these?
Old 08-23-2016, 10:59 PM
  #56
V2Rocket
Rainman
V2Rocket's Avatar
No.
Old 08-24-2016, 03:21 AM
  #57
tempest411
tempest411's Avatar
You can actually just buy one ready to go. That's what I did...seems very high quality, though I don't have a car to install it into yet
http://griffiths.com/porsche/air-con...ac-condensers/
Old 08-24-2016, 10:15 AM
  #58
V2Rocket
Rainman
V2Rocket's Avatar
That does look like a nice piece...the price is good too.
I don't have the time to do these anymore...so I defer to Griffiths.
I have had a parallel flow on my car since maybe 2009? And it works GREAT.
Old 08-28-2016, 02:40 PM
  #59
zeusrotty
zeusrotty's Avatar
Okay, so I've had to remove my old AC/Rad/fans in order to cool the LS3. I just need a universal condensor that will fit into the existing lines. Does anyone know of such a beast?
Old 08-28-2016, 03:13 PM
  #60
tempest411
tempest411's Avatar
If you want something that will connect to your existing lines it will, by default, NOT be universal. Universal means it'll work if you can make it work, as in make up a new mounting system and your own lines & fittings. Definitely doable if you have or can borrow the required tools to do it.
Quick Reply: Bolt-on parallel flow AC condenser
