Bolt-on parallel flow AC condenser
Old 08-28-2016, 07:44 PM
  #61
docwyte
docwyte's Avatar
I had no issues on the street with my RH/RD radiator with shroud and single 11" fan.
It was track use that made me add the secondary radiator.
I kept my AC...
Old 08-28-2016, 08:31 PM
  #62
V2Rocket
Rainman
V2Rocket's Avatar
doc, would love to see that setup if you've any photos
Old 08-29-2016, 01:58 AM
  #63
docwyte
docwyte's Avatar
Pretty sure I posted some pics in my build thread. If they're not there, ping me...
Old 09-02-2016, 11:14 AM
  #64
zeusrotty
zeusrotty's Avatar
I wanted to use an updated condensor though. So that I can run the updated compressor and dryer with the 134.
Old 09-02-2016, 11:28 AM
  #65
V2Rocket
Rainman
V2Rocket's Avatar
If enough people wanted these again I might consider it.
I would need to get some more tools
Old 09-02-2016, 11:39 AM
  #66
zeusrotty
zeusrotty's Avatar
I'm not looking for bracketed. Need to make my own because I had to make a custom radiator support. For my rad and fan setup.
Old 09-02-2016, 12:01 PM
  #67
V2Rocket
Rainman
V2Rocket's Avatar
That looks great.
You have a PM..
Old 03-08-2018, 03:25 PM
  #68
shortyboy
shortyboy's Avatar
Very interested in this. Kuel updated condenser is no longer available. I wanted to overhaul complete AC system. Condenser, compressor, dryer etc. Please let me know if you are still offering these. Thanks
Old 03-08-2018, 06:24 PM
  #69
Ish_944
Ish_944's Avatar
I got a new one from ebay about 1.5 years ago for my early car. Cost around 85 USD. Can't seem to find it now.
Maybe spend some time searching for it!
Old 03-08-2018, 06:48 PM
  #70
V2Rocket
Rainman
V2Rocket's Avatar
I also recall seeing a VERY well priced unit basically identical to the ones I made on ebay, but couldn't find it just now either.
I've thought about making these again but knowing that one was out there frankly I couldn't compete.
Old 03-12-2018, 04:40 PM
  #71
hanick
hanick's Avatar
Has anyone experimented with RED TEK® 12a Hydrocarbon Refrigerant a HC-based refrigerant from Thermofluid Technologies.
Supposedly a direct replacement and retrofit refrigerant option for replacing R134a and R12 refrigerants in automotive air conditioning and refrigeration systems. 12a operates at lower head pressures and offers improved cooling properties and performance verses R134a and R12.
https://www.amazon.com/Cans-REDTEK-Refrigerant-Ounce-Gauge/dp/B00E9W2PPS/ref=sr_1_4?s=automotive&ie=UTF8&qid=1520883471&sr=1-4&keywords=redtek https://www.amazon.com/Cans-REDTEK-Refrigerant-Ounce-Gauge/dp/B00E9W2PPS/ref=sr_1_4?s=automotive&ie=UTF8&qid=1520883471&sr=1-4&keywords=redtek
Old 03-12-2018, 04:56 PM
  #72
V2Rocket
Rainman
V2Rocket's Avatar
why would you bother?
944 with R134 even with stock condenser works GREAT.
plus you'd need to order 2 of those kits to have enough refrigerant to do a 944 system ($130) whereas even in California sufficient R134 costs about $30.
typically stuff sold as an R12 substitute is propane or some other similar type of flammable gas...danger zone.
Old 03-13-2018, 12:36 PM
  #73
jderimig
jderimig's Avatar
Why not just use R12? Take an online certification test $20, easy to pass. Then buy ebay R12 for $20-$30 a can. Yes more than R134 but you have the "good" stuff.
Old 03-13-2018, 10:54 PM
  #74
snb13
snb13's Avatar
This stuff works great:
Enviro-Safe R134a AC Refrigerant + Dye 1 Can
Amazon Amazon
Old 02-16-2023, 01:20 PM
  #75
maybeillbuyit
maybeillbuyit's Avatar
Any chance you are making these again Spencer? Or anyone know of a company making these for early 944? I see Griffith doesn't do the early ones anymore
Quick Reply: Bolt-on parallel flow AC condenser
