Transmission linkage broken bolt suggestions
Old 01-21-2013, 06:10 PM
ritzblitz
ritzblitz's Avatar
Originally Posted by s14kev
I used MAPP gas which should be a little hotter than propane. I did not however make it cherry red like I usually would with a seized fastener/broken bolt since the selector shaft seal is rubber and I did not want the selector shaft to conduct heat and melt the seal which is in the gearbox housing.
I was also a little chicken since there is a plastic fuel tank full of gas just 4 inches above the bolt that I was heating. I can just see the news headlines now.... "Porsche and garage up in flames"
Ok good points indeed.
Good luck with drilling!
Old 01-26-2013, 04:08 PM
s14kev
s14kev's Avatar
No cigar on the extractor. So off it comes!
Quick Reply: Transmission linkage broken bolt suggestions
