92 968 Junk yard Find
+1 you can sell the 6 spd for $2+ at least, $3 if it doesn't howl. Get it, sell off the block and tranny, source an LS1 or 6 (if you're lucky) get a 951 AOR 5 spd transaxle and you will have the 2nd most amazing 968 anywhere.
Having trouble uploading images.
https://sphotos-b.xx.fbcdn.net/hphot...23884920_n.jpg
https://sphotos-a.xx.fbcdn.net/hphot...61661975_n.jpg
https://sphotos-b.xx.fbcdn.net/hphot...21614500_n.jpg
https://sphotos-b.xx.fbcdn.net/hphot...62481619_n.jpg
https://sphotos-b.xx.fbcdn.net/hphot...96898049_n.jpg
https://sphotos-a.xx.fbcdn.net/hphot...69805708_n.jpg
Doesn't look that bad. Congrats. A little elbow grease under the hood and all should be good. I have had engines in some of my projects look worse than that and they turned out just fine.
I spent some time at the yard today. Undercarriage is amazingly clean. Engine had no leaks. Engine looks worse in pics. I think once i get the cylinders looked at and some lube in there, i thing it will all be fine?. the only damaged part was the front cowl.
I am liking it?
I am liking it?
