Sweet supercharger sound after timing belt job
Old 06-02-2013, 11:27 PM
Parawhore
Parawhore's Avatar
Default Sweet supercharger sound after timing belt job
Just finished a timing belt job on my '84 NA and now my car sounds like it has a sweet supercharger. I remember reading somewhere on here that it's usually caused by either the Alternator or Balance Shaft belts being over tightened. But I can't seem to find where I read that. Just wondering which belt I might need to back off a tad.
Old 06-02-2013, 11:43 PM
Mueller944s2
Mueller944s2's Avatar
Balance belt. A little tight is ok though, I keep mine just tight enough to hear that supercharger whine. As long as it's not too much
Old 06-02-2013, 11:46 PM
Parawhore
Parawhore's Avatar
Thanks for the quick reply! I'll back the tensioner off just a bit as the sound is pretty pronounced.
Old 06-03-2013, 01:48 AM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
Just FYI, The balance belt tension roller is tensioned CW to lower the BB below the WP waterpump pulley.
GL
J_AZ
Old 06-03-2013, 02:09 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
I keep my balance belt whiney. Gives it the classic 944 sound lol
Old 06-03-2013, 11:25 AM
VirginiaF1
VirginiaF1's Avatar
If the correct tension is applied via P9201 or Arnworx guage, will the BB's still whine?
Old 06-03-2013, 11:32 AM
turbodave
turbodave's Avatar
Be sure you have the required gap (0.5MM) between the belt and the idler roller at the lower balance shaft pulley. This is the biggest source of the supercharger sound if it is really pronounced.
Old 06-03-2013, 11:35 AM
Van
Van's Avatar
No.
Old 06-03-2013, 01:10 PM
Shawn Stanford
Shawn Stanford's Avatar
Yeah, I've been driving with mine like that since the 60k service a little more than a year ago. A quick search here showed that it's not a problem, it's just an annoyance. I'm dropping the car off for the annual, and I'll have them make the adjustment while they have it.
Old 06-03-2013, 01:25 PM
krystar
krystar's Avatar
BB should be "no way that's too loose" tension. it's just a hair tighter than "whoah that skipped a tooth" tension
Old 06-03-2013, 02:41 PM
John_AZ
John_AZ's Avatar
I have used the Krikit in the past on the BB but now I just pinch the BB with my thumb and finger. If it moves up and down at least an inch the tension is set. Caution YMMV (your results may vary).
I agree with turbodave--set the idler roller correctly--top and bottom.
J_AZ
Old 06-03-2013, 03:19 PM
mike77
mike77's Avatar
Agree with the comments about setting the idler roller correctly. If it is spinning fast all the time while the car is idling then it will make a lot of noise. Correct me if I am wrong but I believe the roller is only there to stop the belt from flapping. Mine is set so that it only comes in contact when I first open the throttle, then the belt settles down once the roller does its job and stops it flapping.
Old 06-03-2013, 05:47 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Ryan Kennedy in Holly Hill (Daytona), FL did my belts/pullies/H20 pump back at the beginning of April.
same exact result with respect to the sweet whine.
Old 06-05-2013, 10:08 AM
PeteL
Got Nothin'
PeteL's Avatar
This was the source of my supercharger-like whine. Gapped it and the sound went away!
Old 06-05-2013, 03:09 PM
Parawhore
Parawhore's Avatar
I wound up backing the tension off a bit and the sound disappeared. I do however, now want a supercharger...
Quick Reply: Sweet supercharger sound after timing belt job
