Running VERY lean, out of options
Old 06-21-2013, 09:22 AM
eric951turbo
eric951turbo's Avatar
Default Running VERY lean, out of options
Hey guys, I'm running out of options here. The car has been running like crap since I worked on it last winter.
Symptoms:
1. Car has no power off boost. Even worst when ac is on. Works ok when turbo kicks in.
2. Vacuum leak at idle. Shows only - 10-11 psi on idle.
3. Engine stumbles when cold start
What I did last winter:
1. Oil pan gasket + rod bearings (disaster job, it still leaks, have to do it again)
2. Remove and reinstalled timing belt and balancing belt to change seal behind the timing back cover
What I did so far to fix the problem:
1. Pressurized the intake for vacuum leaks
- changed all the vacuum hoses
- throttle body seals
- new idle stab valve
- new intake manifold gaskets
- new banjo bolts
- .... I have absolutely no vacuum leaks. Only leak I have is the the 2 o-rings that connect the AOS reservoir. But that is not part of the intake
2. Rechecked the alignments for the timing : ok
3. Swapped computers
4. Disconnected the o2 and reconnected : ok
5. Adjusted the idle a million time
6. Changed the fuel filter, and fuel pump check valve last week (engine was running a bit smoother after that)
6. Installed a wideband : Reading : idle 14.7... slow acceleration : 14.5 to 14.9.... wot around 13.6
Now last night, I told my self:
- intake list : out of the list. I've removed the intake manifold 6 times since spring, pressurized it at least 200times... I've listen carefully... I HAVE NO LEAKS
- Maybe I'll jack the car again, and again put the engine and top dead centre and ckeck the alignment again
- So did morning, I look at my spark plugs... they are WHITE... crystal white
ONE QUESTION: I have read last night that bad timing could create a vacuum leak... Could it make the car run lean?
Old 06-21-2013, 11:54 AM
CyCloNe!
CyCloNe!'s Avatar
test your TPS and 02 sensor they both can cause a lean condition... My 02 is bad so whent it's connected I get 17-18 AFR when it should be around 14.
Old 06-21-2013, 12:00 PM
krystar
krystar's Avatar
running the car w/o O2 isn't catastrophic. it makes the DME go into dumb mode which usually means you're running richer than optimal.
have you checked fuel pressure at the rail? maybe FPR gone bad?
Old 06-21-2013, 12:04 PM
eric951turbo
I finally found the ot mark, + the mark under the car at the bell housing... I had a pro 944 mechanic to redo the belts 2 years ago.
ot mark is spot, but the camshaft mark is way off. I'll take the cover off and see.
I'll start another thread concerning timing.
Old 06-21-2013, 06:14 PM
krystar
krystar's Avatar
WAY off? unless you're 180degrees off, it'll prob mean bent valves.
get cam timing back on. then do compression test.
Old 06-21-2013, 06:27 PM
eric951turbo
Guys... Vacuum leak at idle can also mean bad timing.
I redid the timing on the car, everything is back to normal... Except the engine may be damage (bent valves)... But I just came back beating the crap out of the car on the highway, and its running amazing.
I think i just experienced what having a full Vitesse stage 1 kit is really suppose to be.
Just amazing
I wish i could say the name of a stupid suppose to be pro 944 mechanic who as done the timing on my car here in montreal, but i won't
Please pm me before going to see someone.
Old 06-21-2013, 06:34 PM
eric951turbo
The cam was about 90degree off, for 2 years.
Old 06-21-2013, 07:17 PM
eric951turbo
Only problem is that I couldn't see the ot mark on top of the bell housing... I had to guide with the big mark at flywheel from under the car.
It's hard to get it line up, if you turn the crank 1degree, it moves like 6 degrees from under.
I just hope it's right
Old 06-21-2013, 07:55 PM
MB968
MB968's Avatar
If you have bent valves, I'd think a compression check will be considerable off the norm. If they are bent, I wouldn't run it, as you could loose the top of a valve, and then its pistons, etc. A lot more $'s. If you are lucky, they are still OK.
Old 06-21-2013, 07:59 PM
eric951turbo
Is there a symptom to know if i have some bent valves
Old 06-21-2013, 08:00 PM
eric951turbo
Other than a compression test
Old 06-21-2013, 08:49 PM
kev951
kev951's Avatar
misfire, horrible noised, blue smoke.
Old 06-21-2013, 08:52 PM
Van
Van's Avatar
Yeah - non-running and a really fast "whrrr" sound when the starter turns the engine over... because there's no compression.
Old 06-21-2013, 09:12 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
these 30 year old, low production, semi-exotics.
you call Chris White and ask him really nice if he'd like to come and catch the Stones at the Bell Centre....
oh.... that was 3 weeks ago.
Old 06-21-2013, 10:58 PM
eric951turbo
Well so far, i have none of those symptoms, except for misfiring when the turbo starts spooling up. But that could be a lot things. So far so good. Tks guys
Quick Reply: Running VERY lean, out of options
