manual rack or power rack?
Old 06-27-2013, 12:24 AM
  #31
Volhv_944
Volhv_944's Avatar
True about the alignment! Mine is way off since I eyeballed it after swapping in the rack. One I get the aforementioned tires, it will be done. Only put 130 km on it with the new rack, and most of that was to go get the emissions test.
Old 06-27-2013, 07:39 AM
  #32
MAGK944
MAGK944's Avatar
Originally Posted by lovemyp-car
^^^ What does this adjustment do? does it alter pre-tension on the input shaft allowing the rack to turn more easily?
From what I can see judging by the position of the adjustment bolt, it seems to move the rack gears closer to the input shaft gears via a spring. I guess it adjusts backlash but one way makes the steering lighter and the other way heavier.
So have we surmised that:
Manual stock rack is 4 turns
Manual quick rack 3.5 turns
Power rack 3 turns
That would make sense.
Old 06-27-2013, 10:12 AM
  #33
F40LM
F40LM's Avatar
Interested to see which kind my car has. Might be sport, the car I pulled it from has real sport seats in it.
Old 06-27-2013, 02:33 PM
  #34
Campeck
Campeck Rulez
Campeck's Avatar
I loved my manual rack
Old 06-27-2013, 04:55 PM
  #35
rlets
rlets's Avatar
I think my power rack was 3.5 turns lock to lock. I can't test right now as it's not in the car. This was with a, '87, late offset, non-turbo car.
On the adjuster, my understanding was this is to eliminate play. I suppose if you over do the adjustment too tight, it would make turning the wheel harder. But mine's set right at the verge of there being play, can't go any looser. Oh, and I use a 350mm Momo wheel, 255 r-comp tires, 17x9 ET55 wheels, lots of camber and lots of caster.
Rich
Old 06-27-2013, 05:28 PM
  #36
Yummybud924
Yummybud924's Avatar
Yeah, I love my manual rack too. In parking lots it's noticeably different than power steering but it's not a big deal to me. Maybe if you are an old woman it would be hard to turn.
I picked mine up for 50 bucks I think lol. And picked up a manual shaft from bay for another 50.
I think you'll like it, plus with no power steering you never have to worry about leaks again, and easier to drop the crossmember, and more room under neath when you remove the pump and hoses.
Old 06-27-2013, 05:30 PM
  #37
Yummybud924
so how much are used manual racks worth? I know I got a good deal for 50 bucks.
Old 06-27-2013, 05:46 PM
  #38
MAGK944
MAGK944's Avatar
You did get a good deal! They seem to sell for $200-$300 with the shaft. Like anything 20+ years old you have to make sure they are not worn or the nla shaft bearings are still tight. If there is any play in the rack or the shaft bearings just wobble about, walk away.
Old 06-28-2013, 05:05 AM
  #39
Volhv_944
Volhv_944's Avatar
Got mine with intermediate shaft, for 200 shipped to my door. Beware that the rack gear can actually bend in the event of a front end collision, or even slamming into a curb. So check for that, or the steering will be very tight, and will not go to neutral.
Quick Reply: manual rack or power rack?
