Best fuel lines and Vacuum lines....
Old 07-11-2013, 12:51 AM
ForceReconTrojan
ForceReconTrojan's Avatar
Default Best fuel lines and Vacuum lines....
Taking the advice of the board I am going to replace the plugs, wires, rotors etc. As well as have the injectors cleaned, replace all the lines.
If money is not a issue what would you guys recommend for replacement parts, OEM or...
Many thanks
Old 07-11-2013, 12:58 AM
seafeye
seafeye's Avatar
I just recently got these fuel lines….
http://www.ebay.com/itm/Porsche-85-5...item3a81192038
http://arnnworx.com/fuel_lines.htm
Still have to install them. No hurry while the motor is out. As for the Vacuum lines?
Lindsey Racing has a kit that replaces the small vacuum lines with silicone ones. I have been using them with good results. The larger hoses, i.e.: from the ICV i have been using new OEM from Pelican Parts.
Old 07-11-2013, 01:20 AM
ForceReconTrojan
Thanks much, I will look into both tomorrow.
Old 07-11-2013, 08:22 AM
Ky944TurboNewbie
Ky944TurboNewbie's Avatar
Fuel Lines: (Get both)
http://www.rennbay.com/fuel-lines-c-35.html
Vacuum Lines:
http://www.lindseyracing.com/LR/Part...ACUUMLINE.html
If you need to do the Venturi Delete:
http://www.lindseyracing.com/LR/Pors...A-951-VDK.html
I like the magwire ignition wires:
http://www.lindseyracing.com/LR/Parts/MAGWIRE.html
If money isn't a consideration, I would get the master silicon hose kit from Lindsey.
http://www.lindseyracing.com/LR/Parts/951HOSEMAST.html
I'll let others speak to the other ignition parts. I stayed completely stock with those.
Old 07-11-2013, 09:42 AM
divil
divil's Avatar
You can replace many of your vacuum lines with 5/16" fuel hose and 5/32" vacuum line from any auto parts store...very cheap. For the ones with metal fittings you can just cut the collars off with a small hacksaw (carefully) and re-use the fitting with a hose clamp.
For the specially formed vacuum lines, Lindsey Racing is hard to beat, they have a number of parts that are NLA.
Old 07-11-2013, 10:15 AM
sharky47
Set to Full-Auto
sharky47's Avatar
+1 for both Rennbay fuel lines and Lindsey Racing vacuum lines.
The vacuum lines are are really nice - both my cars have them. You also get metal fittings in the kit, which is a huge plus.
Old 07-11-2013, 03:58 PM
HICKS
HICKS's Avatar
+1
Old 07-11-2013, 05:06 PM
86 951 Driver
86 951 Driver's Avatar
I used the Rennbay deluxe kit for the main lines and for the jumper line I had Boxster GT on Pelican parts make me one.
I used all Lindsey Racing Vacuum lines. I could have gotten it cheaper from the parts store, but I have left supply and I use some of that to plumb my MBC. Totally worth it.
Old 07-11-2013, 11:46 PM
ForceReconTrojan
Thanks guys, I bought 345 hoses today from Lindsey with their Master Hose replacement setup, all black except for the Venturi delete which they were out of stock on and opted for Red to match the Performance wires I bought as well.
Got their turbo blanket and then ordered the light upgrade from rennbay.
Too be honest my 987CS and E30 M3 parts cost so much more than 944 parts this wasn't so bad considering. So my advice to you guys is buy parts for old BMws and new Porsches and your 944 will seem downright cheap
Thanks again to all that helped, I really like this board a lot. My car is getting picked up tomorrow and I will have it next weekend if all goes as planned.
Here is my CS so I can at least post something Porsche.
Old 07-12-2013, 08:23 AM
sharky47
Set to Full-Auto
sharky47's Avatar
That car is sick! Love the shape of those and it looks great in white, well done!
Quick Reply: Best fuel lines and Vacuum lines....
