Wheel adapters
Lol doug. Thats a common joke in my workplace.
I will use anti seize, the only problem is this is a PO job... and I live with an 88 year old grandpa I will get a neighbor to help out and lock the brakes to see if I can get them loose. have PB blaster marinating in there now. anyone have advice on doing this solo? breaker bar and some kind of stop on the studs? I'm open to anything
One breaker bar on one lug, a second breaker bar on another lug, turn in opposite directions. Thing is that you run the risk of ringing off a post. Or you could rent an air impact setup from a local tool rental place. good luck.
Have someone hold the brake pedal..or stick a screwdriver into the disk(against the caliper) to stop it from rotating.
If they are for sale i'm interested !
Sorry guys. Not for sale. Just going through suspension that the PO set up..
