LED headlight upgrade completed
Old 08-01-2016, 11:45 PM
  #91
1096369
1096369's Avatar
Apparently I was too dumb to notice that the $82 price tag was for only one light...... In for a penny..... The singular bulb I did get in the mail looks like a very good quality unit.... I ordered the second one today, since my 944 is not to the best of my recollections ..... A motorcycle.....
Never made any claim to being the sharpest knife in the drawer....
Fred
Originally Posted by 1096369
Hey Nihil,
I have no doubt.... You are absolutely right..... And I am sure I Will suffer as a result.....But I am not real bright.... And gotta do things the hard way.....
I ordered a set of these..... For an $80 gamble..... I won't kick myself in the *** to badly when they go south..... But I gots to know!!!!
http://www.carid.com/spec-d/7-round-...7rndjm-ms.html
Old 08-03-2016, 08:57 AM
  #92
1096369
1096369's Avatar
Hey Girls,
I installed my left LED, (as I patiently wait for Brown Santa to bring my right one!��). Here are a couple of pics....
Low Beams:
High Beams:
Old 08-03-2016, 09:11 AM
  #93
1096369
1096369's Avatar
Old 08-03-2016, 09:23 AM
  #94
1096369
1096369's Avatar
It just occurred to me that what I "should" have done is "the wall" test (bridge pier, in this case) is cover left, take pic, and then uncover, and cover right, take pic. At the same distance and conditions to give a better idea of individual performance..... Will try to do that tonight...... My initial impression..... I REALLY like these lights!!! I'm amazed at the knife edge cut off.... And clarity over distance.... I live in Eastern Bucks County PA..... Where venison on the hoof is a major problem..... I think these will help spot Bambi before she ends up as a hood orniment!!!
Oh, while on the subject of lighting.... Not sure if anyone has tested these LEDs for the dome lights.....
They are Super bright, and appear well made, they are about 1/4" shorter then the factory bulb.... But with th judicious use of a set of needle nose pliers..... Was good to go!!!
https://www.ebay.com/itm/201265343854
Old 08-04-2016, 12:29 AM
  #95
1096369
1096369's Avatar
Default W
Here are the pics. I promised..... Started with the factory headlight covered.....
LED low beam:
Factory low beam:
k
LED High Beam:
Factory High Beam:
*FYI the bridge pier is aprox. 25 yards from the front of the car.
  #96
V2Rocket
Rainman
V2Rocket's Avatar
can you take a beam shot with the halogen bulb unplugged?
the beam shown on the wall isn't very good.
Old 08-04-2016, 12:45 AM
  #97
1096369
1096369's Avatar
Here ya go V2Rocket....... (See above), Sorry for the crappy IPhone pics.!
Old 08-10-2016, 11:51 PM
  #98
1096369
1096369's Avatar
Final Pics with both LED headlights:
Low Beam:
High Beam:
For $160 a Hugh improvement, easy plug and play install!
Old 09-02-2018, 10:19 AM
  #99
Dave951
Dave951's Avatar
Checked today Superbrightleds discontinued the 7" sealed units reviewed in post #78
Old 09-02-2018, 01:04 PM
  #100
StoogeMoe
StoogeMoe's Avatar
I hate the LED headlights in my truck. See that sharp cutoff of the light? I don't know how they pass safety requirements. You go over a hill in the road, and the light points down and you can't see 15 feet in front of you. Unacceptable!
Old 09-02-2018, 01:34 PM
  #101
MAGK944
MAGK944's Avatar
+1, if they are not adaptive led headlights they are almost useless on anything but perfectly straight and smooth roads. Afaik when manufacturers (including Porsche) fit led lighting they are designed to adapt to road conditions using steering and pitch sensors.
Old 09-28-2018, 11:46 PM
  #102
GrantM
GrantM's Avatar
That's too bad about the headlights, they're great!
Old 12-17-2018, 04:51 AM
  #103
Otto Mechanic
Otto Mechanic's Avatar
Thanks for that tip Mike (and Moe). I've been looking at LED projectors for mine, I'd like to install the GTS style headlights and remove the pop ups, I know it's sort of sacrilegious but I think even Porsche did it on a few cars. Anyway, I thought while I was at it I might upgrade the lights. It sounds like doing it right is a whole lot more work than just installing new lamps/projectors.
Old 12-19-2018, 11:33 PM
  #104
Arominus
Arominus's Avatar
The real ticket in the pop up housings is the Cibie h4 housings, high wattage bulbs and the relay harness. The GTS style is nice too, but the light output is not quite as good as the H4's from what i've read, because of the covers.
Old 12-20-2018, 01:18 PM
  #105
lamrith
lamrith's Avatar
I see a couple Cibie offerings. Are those the Cibie E-code H4 7" housings you are refering to?
Or maybe these ones?
Cibie 82440 Light Unit Cibie 82440 Light Unit
Quick Reply: LED headlight upgrade completed
