The mystery relay
Old 03-10-2014, 05:51 PM
Van
Van's Avatar
Originally Posted by Lilja
So actualy in theory it could work with any relay that has an 87A exit if Im not completely off now couldnt it?
No, just any old relay won't work... this relay clearly has some sort of logic on it - it's functioning as more than just a basic switch.
Hopefully people will be able to find one like it and get you a part number so you can order a new one.
Old 03-10-2014, 09:48 PM
schibsted
schibsted's Avatar
There's a 555-timer IC on that board, so its doing something at an interval/timing something. i'll try to see if i can find one on my car
Old 03-10-2014, 10:06 PM
schibsted
schibsted's Avatar
I think its this relay: PN 94461591501.
Based on the fact that this relay is the only one i dont know what does, and i found a thread with has pictures of it with 4 posts; https://rennlist.com/forums/924-931-...a-hundred.html
I found this relay in PET only listed as "Relay -- see technical information GR.2 NR.3/85" If anyone know what that means or where to find it that would be awsome
EDIT: More threads which state that engine does not run without this relay; http://www.kcws.org/forum/showthread.php?433-What-relay
Old 03-11-2014, 08:42 PM
StoogeMoe
StoogeMoe's Avatar
I looked on my car, and I have two relays under there, mounted right near the center console. They are near the altimeter sensor, so maybe it has something to do with that?
Old 03-11-2014, 10:03 PM
konakat
konakat's Avatar
Do they have the same number and arrangement of connections? If so what are the part numbers on the relays?
Old 03-12-2014, 04:05 AM
Rich Sandor
Rich Sandor's Avatar
Lilja.. based on some reading I've done, that was an 'experimental' relay (basically a "flasher blocking relay") Porsche put into some 84-85 models which altered the air-fuel ratio going into the computer (pin#13 I think) for the first ~2min~40seconds or so. The same way a flasher relay intermittently blocks the power to a turn signal light (making it flash) the relay would interrupt power to a function in the DME that would alter the air-fuel ratio. (Possibly by interrupting fuel injection cycles)
This function was later provided within an updated DME relay, which is why it is not there in later cars. Some more research indicated it is indeed part number 944.615.915.01.
There is one for sale on eBay.co.uk for ~40usd.
Old 03-12-2014, 04:22 AM
Rich Sandor
The tech bulletin GR2 8503 is as attached below in PDF.
It basically says that there are different injectors for Porsches which may look the same but have different internal resistances.
Possibly this relates to the relay somehow.. they used the relay to make up for different injectors? who knows.
File Type: pdf
Old 03-14-2014, 09:13 AM
Lilja
Lilja's Avatar
I noticed now I accidently replied in the wrong thread
Anyways yes this has to be the correct relay, atleast it looks exactly the same on the bottomplate. Gonna check with my dealer if he has one, he claimed he had one but needed the partnumber to make sure.
Thank you for all your help thou and hopefully we all learned something new with this
Quick Reply: The mystery relay
