FS Brake Hoses, OEM Fuel Lines/Hoses/Cooling Hoses, Used 944S parts, + A Lot More!
Under the Radar
Prices include shipping!
NEW:
Rear Brake Pad Retainer Kit (944-352-952-00) $60
Front Brake Hoses - ATE $70 FOR BOTH
Rear Brake Hoses - FTE $20 FOR BOTH
FRONT ATE Caliper Rebuild Kits $35 FOR BOTH
REAR ATE Caliper Rebuild Kits $15 FOR BOTH
OEM Fuel Pump Suction Strainter $40
Fuel Hose/Line - BRAND NEW OEM - 944-356-027-11 $35 - I believe this is one of the hoses that go across the exhaust manifold for the Porsche 944S. It is very important to change because this can easily cause a fire if it leaks.
Fuel Hose/Line - BRAND NEW OEM - 951-356-047-03 $40
OEM Cooling Hoses Two NEW rear heater core to engine hoses (#944-572-589-00 and #944-572-587-02...Keep in mind these are OEM PORSCHE HOSES, not cheap chinese CRP/URO) - $35 for both. These are important hoses to change because they are not very accessible to get to if you break down on the side of the road.
USED (DOES NOT INCLUDE SHIPPING COSTS):
AC Compressor - No idea on the condition $25
PS Turnbuckle - $20
AC Turnbuckle - $25
Starter - $25
944S Airbox with Plastic Tube extension - $75
Alternator (New Voltage Regulator Installed but it is dusty, may want to rebuild bearings and clean it) -$50 ($20 + voltage regulator cost)
ABS Computer - $50
Passenger side aluminum A Arm (good condition, no cracks) - $35
USED PICKUP ONLY!
8V Transaxle - $100, LATE MODEL TRANSAXLE NON LSD CODE STAMP
16V 944S Engine (Ad - https://rennlist.com/forums/924-931-...and-xpost.html)
NEW:
PS Turnbuckle - $20
AC Turnbuckle - $25
Starter - $25
ABS Computer - $50
USED PICKUP ONLY!
