Fontana Festival of Speed- Anyone going?
Freedom Enthusiast
Anyone going to the Festival of speed in Fontana this Saturday?
https://rennlist.com/forums/for-sale...ontana-ca.html
I'm going and bringing a lot of parts for the swap meet.
Here's the list.
Vitesse AFM chip
Autothority AFM chip
Turbo Block
Turbo Crank
4 turbo pistons with wrist pins
2 turbo pistons without wrist pins
2 balance shafts
4 balance shaft covers
power steering pump brackets
power steering reservoir
power steering pulley
crossmember with oem engine mounts
4 original fuel injectors(probably need a rebuild)
Black Llyods floor mats(full set)
Plastic fuel rail cover with all tabs
A/C pump
factory down pipe
Alternator(questionable condition - good for a rebuild or core charge)
Complete turbo airbox with broken tabs
Factory wastegate with weltmeister shim
AOS pipe
A/C hard line
Lindsey Manual boost controller
Red Lindsey radiator hose kit(missing a few hoses)
2 Sylvania Halogen headlights
Turbo water crossover pipe
Plastic headlight surrounds
Metal headlight covers
Turbo J-boot
Factory sway bar with new mount bushings
Almost new turbo water pump hose
Black vinyl Mirror covers
Stock FPR
Intercooler pipe TB side
Exhaust hangers
Torque tube hanger
Power steering rack(unknown condition)
Front plastic turbo/S2 side skirts
Plastic emissions canister
Red silicone vacuum hoses with T's
Oil cap
Shift boot(needs recovering)
S2 Factory cat back exhaust
Red Magnacore plug wires(unknown mileage but they look almost brand new)
Red Lindsey Firebraid plug wires(almost new - less than a month of use)
Lower front belt cover(cracked)
Here's the list.
Vitesse AFM chip
Turbo Block
Turbo Crank
2 balance shafts
A/C pump
factory down pipe
AOS pipe
A/C hard line
Turbo J-boot
Stock FPR
Exhaust hangers
Torque tube hanger
Oil cap
Freedom Enthusiast
It looks like the original thread has disappeared. It is tomorrow.
I hope there is a good turnout. I don't want to haul all this stuff back to Phoenix.
Freedom Enthusiast
