Ford Mustang 5.0 injectors
I have a 1988 Turbo and need new fuel injectors. Has anybody heard of using Ford Mustang 5.0 injectors? And if so do I need to do any modifications to my fuel delivery system?
Rainman
Are you looking for stock-flow rate fuel injectors, or larger?
The closest Ford injector you'll find is from the late 80s 2.3 turbo engines (Mustang SVO/Thunderbird turbocoupe), 36lb/hr, low impedance (2.4-2.8 ohm)
944 turbo uses 36lb/hr injectors but has a weird impedance, like 5.5ohm. If you use the Ford 2.3 turbo injectors...you can add resistors to the injector wiring to bring the circuit resistance back to spec...if you want.
Or just buy re-built 951 injectors.
Basic Sponsor
I have seen a car using mustang injectors, can I have the part # for those injectors? Are those the same for the Cosworth engine?
Basic Sponsor
No the ford costworth Sierra injectors
