Wheel Fitment Help
Hi Scott , the standard 944S2 has front wheels with a ET ( offset) of 55mm & 7" wide , so with a ET28 the front rim/s will stick out an extra 27mm + the extra width , meaning 8" wide dived by two = 4" , compared to the standard 7" = 3.5" ( extra half inch or 13mm ) , so that means the outer rim lip will sit out the extra 27mm + 13mm = 40 mm
Not only will they not fit ( sitting out 40mm ), but the scrub radius will be so far out it will be undrivable
Note } a scrub radius change of even 5 mm makes most last century Porsche's slightly more prone to tram tracking ( nervousness in the steering & follows the camber of the road = not good ), 13mm change in scrub radius makes most last century Porsche's tram track quite badly , so a 40mm change would be very very very bad ( read dangerous )
