what can I use to lube fuel lines
Old 08-04-2014, 06:33 PM
Yummybud924
Yummybud924's Avatar
Default what can I use to lube fuel lines
I removed my rennbay fuel lines and I have to push the return hose back on and need to use some kind of lubricant to get it on. last time i used aft but I have no aft around right now.
could i use a bit of oil maybe? I'm not sure if it would damage the rubber.
Old 08-04-2014, 10:16 PM
Van
Van's Avatar
Fuel lines can handle oil. Like fuel, it's also a petroleum product.
Old 08-05-2014, 01:38 AM
plumbum
plumbum's Avatar
Oil...silicone spray...bit of spit should all help out
Old 08-05-2014, 02:04 AM
Paulyy
Professional Hoon
Paulyy's Avatar
grease is a petroleum biproduct.
Old 08-05-2014, 04:26 AM
Yummybud924
ok thanks guys. I have the older style rennbay lines and i'm always unsure of how tight I should tighten the clamps.
Old 08-05-2014, 08:55 AM
curtisr
curtisr's Avatar
Grease is the word.
Old 08-05-2014, 09:14 AM
ZR8ED
ZR8ED's Avatar
Originally Posted by curtisr
Grease is the word.
Haven't you heard? The bird is the word.
Old 08-05-2014, 11:37 AM
curtisr
curtisr's Avatar
Word!
Old 08-05-2014, 12:25 PM
wingnut
wingnut's Avatar
There are fuel resistant lubricants, DC-4 or EZ Turn are a couple. It is what I use when lubricating the fuel primer (o-ring'd piston pumps) in light aircraft, and the oil filter gaskets.
Old 08-06-2014, 09:20 AM
HICKS
HICKS's Avatar
I used......gas. Slid right on.
Quick Reply: what can I use to lube fuel lines
