My Turn Signal Relay is Buzzing and I Don't Know Why!!!
And I mean buzzing loudly, like an alarm!
I have a 1984 n/a. Anybody have an explanation and/or fix for a buzzing turn signal relay under the dash? It sounds when ignition is off and turn signal lever is centered (not signaling left or right turn). If I turn key one click in (power on but no ignition), the buzzing stops. If the engine is on, the buzzing is off.
If I pull out the relay, obviously, it stops. Other conditions: my dash blinker is out, but it's been out longer than the buzzing, which just started yesterday.
Is this something that replacing the relay will solve? Or cleaning a ground or replacing a fuse?
I don't know how to chase a short, but if that's it, can somebody point me to the likely culprits/locations?
This might cause me to fail my overdue safety check. Thanks in advance.
