Upper Strut Mount Question - Early V. Late
Old 08-21-2003, 03:03 PM
Tabor
Tabor's Avatar
Default Upper Strut Mount Question - Early V. Late
Is there any reason that I can't replace my 1987 944 strut mounts with the cheaper 1983-86 variety?
I notice that all of the aftermarket mounts (camber plates) work for all years.
Thanks Again.
Old 08-21-2003, 06:33 PM
Tabor
Tabor's Avatar
bump...
Danno? Skip?
Old 08-21-2003, 07:43 PM
Shawn944
Shawn944's Avatar
Tabor
They won't work, The later strut mounts are at a different angle than the earlier ones. I think that it is because of the wider track for the ABS. I found this out when I converted a set of early struts to work on my 87 na.
Shawn
87na automatic
Old 08-25-2003, 06:19 PM
Sean M.
Sean M.'s Avatar
What are the DOWNSIDES to installing the "early" strut mounts?
I am replacing the strut mounts in my 1986 944. I was planning to install the updated 951 mounts - and then I saw the price.
Any harm in sticking with the original ($30) mounts?
Old 08-25-2003, 10:58 PM
Shawn944
Shawn944's Avatar
You can't attach the bottom of the strut to the spindle. It doesn't line up
Shawn
87 944na
Automatic
Quick Reply: Upper Strut Mount Question - Early V. Late
