PPI - leak down, compression test or both?
What do folks recommend as part of a PPI? A leak down test, a compression test or both? I've talked to a couple mechanics and have gotten two different answers as far as which is more valuable. Thanks.
Do a compression test first. If the results are good there's no need for a leakdown test since there won't be much leakage. If comp is low or below normal, then do a leakdown test to determine where the leakage is coming from.
walfreyydo (04-29-2022)
audi49 (04-29-2022)
