'86 951 5-speed: rear differential fluid = transmission fluid?
Old 05-28-2015, 12:54 AM
Mister Quickie
Mister Quickie's Avatar
Default '86 951 5-speed: rear differential fluid = transmission fluid?
I got a letter from the shop stating I'm due, based on mileage, for a rear differential fluid change.
I looked on the 'net for a procedure on this and it's the same thing as what I did when I changed the transmission fluid.
Is it the same thing?
Old 05-28-2015, 01:33 AM
odonnell
odonnell's Avatar
Yes. It is a transaxle
Old 05-28-2015, 03:02 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
Typically transmission fluid is for an automatic transmissions and gear oil is used for our transaxles.
Old 05-28-2015, 08:44 AM
Jfrahm
Jfrahm's Avatar
It's hard to change the rear differential oil in a 944 without changing the transmission oil (real hard). It's also hard to want to, as there is no combustion back there the oil lasts a long, long time. I think the spec is to change at 60K but you could consult your manual and as always adjust to account for track usage, boat towing, etc.
If you have an LSD your transaxle oil choice needs to account for this.
-Joel.
Old 05-28-2015, 08:54 AM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Always use the heavy duty stuff if you tow a boat with your 944/951.
Old 05-28-2015, 10:21 AM
V2Rocket
Rainman
V2Rocket's Avatar
if its over 30 ft, use heavy duty moly with a grease gun
Old 05-28-2015, 12:43 PM
SloMo228
SloMo228's Avatar
If you're having the shop do it, make sure they use a GL-4 gear oil. Most modern cars use GL-5 oil and that's what's commonly available, but that type of oil supposedly attacks the brass synchros in older transmissions not designed for it.
Old 05-28-2015, 12:47 PM
odonnell
odonnell's Avatar
A lot of modern GL-5s don't have that problem, just use google to find out whether your choice in oil is safe for yellow metals.
Old 05-28-2015, 12:48 PM
Jfrahm
Jfrahm's Avatar
Don't be ridiculous, you'd never get a 30-footer up a slimy boat ramp with 951 gearing. You'd need at least a 928 with the 4-speed automatic.
Old 05-28-2015, 01:50 PM
Scott at Team Harco
Just a car guy
Either that or a 914. They've got the weight right where you want it. Just below the waterline...
Old 05-28-2015, 06:19 PM
BoulderGeek
BoulderGeek's Avatar
If you just got a 140K mile 944, would you swap out the gear oil in the transaxle, just to be proacive?
Old 05-29-2015, 02:29 AM
mrgreenjeans
mrgreenjeans's Avatar
Location: Marco Island , FL --- Red River Valley, midwest
Yes, Absolutely.
Do you have any record as to when it was done, or if it ever was ?
As to the transaxle lube, I have found Swepco 201 the one product that seems to deliver. It will transform your shifting into slicing warm butter with a hot knife. Your synchros will love the stuff......
If you have an LSD transaxle, as noted by 220 on your build code tag, the Swepco has what is required to extend the life of the clutches in there. No need to add a friction modifier.
Expensive , but oh so worth it. For track and / or everyday highway use.
Old 05-29-2015, 08:59 AM
NoRush993/951
NoRush993/951's Avatar
I used Royal Purple gear oil which is safe for yellow metals and available at the local parts store.
Old 05-29-2015, 11:24 AM
BoulderGeek
I have records on the car, but haven't gone through them all, yet.
I will look for transmission service. The prior owners tracked the car lightly at PCA events, and paid good attention to the belt/WP services and suspension, so I hope they would have done it at some point.
The car definitely appreciates rev matching rather than having the synchro take up the downshifts.
Old 05-29-2015, 12:36 PM
GTgears
GTgears's Avatar
Because it is a transaxle you absolutely want a gl5 oil in there, not gl4. Swepco 201 is an excellent choice. Carquip on Arapahoe sells it and can do the device if you don't want to do it yourself.
Quick Reply: '86 951 5-speed: rear differential fluid = transmission fluid?
