Solid-State DME Relay- Beta Testers Wanted
Old 08-26-2019, 11:50 AM
  #211
Ftech9
Basic Site Sponsor
Ftech9's Avatar
Default New Lower Sale Price
I am pleased to announce the Solid-State Relays for the 993, 964, 968, 944, 924S are now being offered at the lowest sale price ever! This lower price is a direct result of having source a German manufactured relay enclosure. However, I had to invest upfront in a huge industrial batch of these enclosures. The intention to sell a higher volume of theses relays to justify this investment. I hope for support in the Porsche community so I can continue to innovative make these and other high-quality products available to everyone.
Old 08-26-2019, 12:07 PM
  #212
Dan87951
Dan87951's Avatar
Any plans to do some 928 work? The LH computers in 928s are prone to failure and we could use a nice aftermarket source like you have done with the 944.
Old 08-26-2019, 02:38 PM
  #213
mj951
mj951's Avatar
Just ordered one as a spare, thanks!
Old 08-27-2019, 04:34 PM
  #214
tc944
tc944's Avatar
Put one in the race car last fall. Zero issues since then. So much better than the junk that is out there.
Old 08-27-2019, 10:50 PM
  #215
WolfeMacleod
WolfeMacleod's Avatar
Been considering these for my 924S, 968, and relays for my 911. Bulk discounts?
Any plans for an 80's 911 DME?
Old 09-06-2019, 10:36 PM
  #216
Sajan
Sajan's Avatar
I had a URO parts relay in the 3.2 carrera. Tried to order one of these in january but it was sold out.
Ended up getting a Wittrin one, first one didn't start up. Exchanged it for another one..it worked. In June there was an instance of no start up but 2nd try was fine. I was filling up at a gas station.
Today I tried to start it up after not driving for about 10 days...nothing. It's been crazy hot here in Houston. 100+ for days now.
I had the URO one in the glove box and car started up just fine. After a short drive I swapped the Wittrin back in, no go.
Was about to order a stribel one when I thought of this SSR one. I was excited when I saw it back in stock at the right time! Hope this works. I will report back.
Old 09-06-2019, 11:37 PM
  #217
mj951
mj951's Avatar
Received mine the other day, works great!
Sajan (09-07-2019)
Old 09-09-2019, 09:48 PM
  #218
Sajan
Sajan's Avatar
Got mine today! Swapped it. She fired up QUICK.
Hopefully it stays that way for a loong long time.
Old 09-11-2019, 03:17 PM
  #219
phL
phL's Avatar
just bought one!
thanks!
Old 10-29-2021, 04:39 PM
  #220
Ftech9
Basic Site Sponsor
Ftech9's Avatar
Default Diagnostics Solid-State DME Relay
I just created an optional "Diagnostics" version of the Solid-State DME relay! You can now add four LEDs that are connected to the inputs and outputs letting you know instantly if there is an issue. Here is a description of each LED:
Ignition SW – (Yellow) Input signal to power up fuel injection system and enable fuel pump control.
Fuel Inj. Power – (Red) Output indicating the fuel injection system is powered up.
Ctl. Fuel Pump – (Green) Input signal indicating the DME has commanded the fuel pump on.
Fuel Pump – (Blue) Output indicating the fuel pump is powered up.
http://www.ftech9.com/
The following 8 users liked this post by Ftech9:
75ohm (10-29-2021), abiazis (07-07-2022), AKCJ (11-01-2021), AkechiMotors (10-30-2021), DasSilberWedge (10-31-2021), J1NX3D (10-29-2021), jeyjey (10-29-2021), ktonini (10-31-2021) and 3 others liked this post. (Show less...)
Old 07-07-2022, 05:11 PM
  #221
abiazis
abiazis's Avatar
Is the diagnostic DME still available? If so...where can I buy the solid state DME?
Old 07-07-2022, 06:42 PM
  #222
J1NX3D
J1NX3D's Avatar
https://www.ftech9.com/new-products
Quick Reply: Solid-State DME Relay- Beta Testers Wanted
