WTB 31mm hollow torsion bars
Rainman
whats the spring rate youre looking for? maybe we can help you find a solid equivalent.
i understand the purpose of hollow t bars but i dont think they're really worth any added cost...a solid torsion bar weighs about 5 lbs, even a thick one might be 6-7lbs max...so youre looking at 10-14 lbs between the two, what will the hollow ones save you, and will that be worth the extra $1-200?
It helps if we talk about torsion bars in terms of effective rate rather than actual size. Certainly a 31mm effective rate hollow bar is larger than 31mm. Sander can take FOREVER but ultimately they come through.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Rainman
gotcha
then to the OP, i sincerely hope your search for these bars is for a track-only car.
i have 26mm bars and on some streets the bumpiness/harshness/noise is unbelievable.
and all my bushings and things were replaced when installing the bigger bars in december.
Ok, you want 30mm effective hollow bars then. I'm kinda with Spencer, 30mm solid will be much easier to find and I'm not sure it's worth the hassle trying to locate hollow versions.
Rainman
Hates Family Guy
