Tail light won't work, tried a couple new bulbs, connection looks solid
Buy a test light or make one out of a piece of wire harness. Test to see if you have voltage to the bulb sockets. If not go to the fuse box and check for a burnt out fuse If you do have voltage to the socket then you either have a bad ground or bad socket
Take the plastic top to a spray can..paint etc..fill it with apple cider vinegar..remove all the connectors on that one taillight and drop them into the vinegar..Tomorrow they will all be nice and shiney..add dialectric grease all over the connectors, plug in the bulbs and let that light up your life a little bit...hope this helps some..worked for me.
Everything works right up until it doesn't. Those lights may still "work" but I can assure you they are dimmer than they should be.
I presume from your last..that you get power feed right up until the wires connect to the bulbs. and then it quits? Good chance that corrosion has eaten away a lot of the copper wire back a bit from the connectors, and also perhaps that there is only 1 or 2 strands of the copper making contact. Sounds like it's time to clip off the connector, skin back the insulation, and re-wire the connector if it's clean. Then solder it using resin core solder..then heatshrink the joint.
I did the vinegar and the contact leads are shiny now but the one for the taillight still doesn't work.
When I put the other bulbs against the metal housing and touch the bottom tip to the lead (eliminating the bulb sockets) they all light up (brake, reverse, blinker) but when I do it for the taillight it doesn't light and I used a couple different bulbs.
So it would appear that the wire going to the taillight is bad which is the worst case scenario since there's no way to tell where in the path from fusebox to back taillight it's bad.
I hope I'm wrong but if I'm not, are there any options aside from replacing the entire wire harness?
Can you put a meter onto the wire? positive goes to the wire, negative to the chassis of the car. Do you get any voltage reading? What color is the wire? I think that the Germans use a brown wire for the ground. I'll have to check mine out. But if you are testing, say, a black wire, you should be getting voltage to it. If not, go back up the harness to a chassis plug and see if that is corroded or that you are getting current at that point. If so, you just need to re run a new wire, not the whole harness. That wire would run from the plug or wherever you get a current path, to the taillight. Hope this helps some..
Is this a cruise light or a brake light? If it's the brake light, put a piece of wood between the seat and the brake pedal and slide the seat up until the wood depresses the pedal. The brake light should light up. I think that those are 2 filament bulbs, with both the brake and tail light enclosed in the same housing.
