What does it take to make a 2.5 behave better?
Old 10-01-2015, 11:11 PM
944teen
944teen's Avatar
Default What does it take to make a 2.5 behave better?
Is there anything that can be done to the 2.5 to make it rev faster,run better, and overall be more playful? Or mods that can be done to make the car feel faster? Besides an LS of course
Old 10-01-2015, 11:39 PM
Arominus
Arominus's Avatar
Remove as much weight as you can stand to from the car.
Old 10-01-2015, 11:47 PM
Noahs944
Noahs944's Avatar
My solution is to make sure the belts, water pump & rollers are good & drive it 3500-6500 rpm routinely. Thinking of MAF/MAP conversion for better get up & go.
Old 10-01-2015, 11:48 PM
Reimu
Reimu's Avatar
A chip made my 944 feel a lot smoother and a little peppier
You give up 87 octane for it though
Old 10-01-2015, 11:49 PM
V2Rocket
Rainman
V2Rocket's Avatar
put the throttle-response cam on, if you dont have one already.
get an offset camshaft key in 2 or 4 degrees, and advance the camshaft.
find a MAF conversion or run the car on megasquirt to get rid of the AFM.
the car will feel amazing after these steps.
Old 10-01-2015, 11:55 PM
Karl_W944
Karl_W944's Avatar
Does the MAF conversion do anything other than fix that idle drop when you rev above 1200rpm?
And what about the cam key, what's the difference between 2 and 4 degrees in advancement?
I'm curious as to what else I could do for fun on my car. I will say the funnest thing I did was change the trans fluid and basic maintenance. It's so much fun to wind this motor up to 5-6000rpm and shift into 2nd with satisfaction every time!
Old 10-02-2015, 12:18 AM
V2Rocket
Rainman
V2Rocket's Avatar
you tell me
terrible photo i know, but the blue line is stock dme/afm...red is MAF kit +2* advanced cam...
my car would drag a stock 944 backwards.
Old 10-02-2015, 12:42 AM
Karl_W944
Karl_W944's Avatar
That's with a 2 degree? What would the +4 do?
Old 10-02-2015, 07:36 AM
CVR_Rally
CVR_Rally's Avatar
I wish the MAF conversions were more available. I can't seem to find one for the 944S even though I know once was being worked one. With our aging AFM's I would think the demand would be stronger.
Chris
Old 10-02-2015, 10:08 AM
V2Rocket
Rainman
V2Rocket's Avatar
Someday I'll find out for sure and try +4, but the car runs great at 2
Going from straight-up timing to 2 advanced was worth 4whp/7wtq on the dyno.
I would think 2 more degrees would be about the same, but probably a little less.
The tradeoff is that peak power moves down, my peak is about 5600rpm, but my car still makes more power past peak at 6400rpm than it did anywhere with the AFM. Which makes it faster.
The demand exists for the 944 MAFs, but there is a lot of work that goes into them, and not enough people that know how to crack the DME code. The 944S DME is very different than the 944 NA DME. That said...send your interest off to Lindsey racing and they may be able to help you out.
Old 10-02-2015, 10:11 AM
odonnell
odonnell's Avatar
To the OP: what is your (realistic) budget?
You can't beat basic maintenance for making the car run smoothly. Things like fixing vacuum leaks, replacing the fuel filter, air filter, cap and rotor, replacing the FPR and damper (if they are original or undocumented), and replacing the DME temp sensor will clear up poor running due to worn out parts. Sometimes even stuff like new spark plugs makes a noticeable difference. When running correctly a stock 944 engine will start and run smoothly. Cleaning grounds also never hurts.
A couple products you might consider in addition to what has been mentioned already: silicone vacuum line kit, and throttle body rebuild kit (Arnnworx).
As far as performance, there are a million threads. But as stated earlier, depends on your budget. MAF kit will wake things up if you can get your hands on one. I'm a huge cheerleader for standalone (particularly, the Megasquirt range of controllers) but I can only recommend that if you are very comfortable with the stock injection/ignition configuration and have $800+ to burn on just one project. Oh, and you'll need to learn how to tune. But at the end of it, you'll know a TON not only about your car, but modern fuel injection in general. Plus tuning is a great skill to have.
Old 10-02-2015, 10:38 AM
Noahs944
Noahs944's Avatar
I ran with the 4 degree advance with stock head. Just like the throttle cam it was noticeable right from the start.
Old 10-02-2015, 11:25 AM
V2Rocket
Rainman
V2Rocket's Avatar
really woke the thing up, right?
Old 10-02-2015, 12:23 PM
Karl_W944
Karl_W944's Avatar
Wait, so +4 would be less or worse whp/wtq than +2? Why is that?
Old 10-02-2015, 12:27 PM
V2Rocket
Rainman
V2Rocket's Avatar
No, I would expect +4 to gain more power and torque over +2.
But I don't think the gains from +2 to +4 will be as much as they were from +0 to +2. They may be the same or even better, but I think there are other factors that would come into play moving the powerband to the left that much (airflow through ports/manifold tuning, valve to piston clearance maybe inhibiting flow? I don't know.)
IE, +2 got me 4whp/7wtq. I would expect +4 to net an additional +2-3whp/+4-5wtq over the +2 gains.
So I would expect the net of +4 over +0 would be +6-7whp/+11-12 wtq.
Quick Reply: What does it take to make a 2.5 behave better?
