10 minute project: making black plastic look like new!
Old 11-04-2015, 10:30 PM
odonnell
odonnell's Avatar
Default 10 minute project: making black plastic look like new!
I remember reading on a Jeep forum a while back about restoring faded black plastic trim (in their case, wheel arches) by simply using a heat gun on it.
I have this crappy looking fuel rail cover, missing bits and more about to fall off. It is badly faded to a dark gray and is blotchy in places (you can even see it in my current avatar picture). Could care less about it so I decided to heat gun it, just to see.
It really works! Just a PSA to anyone with faded plastic bits. The fuel rail covers are NLA so I thought that alone was worth sharing.
You want to 1) clean it off thoroughly with soap and hot water. Make sure it's dry after. 2) hold the heat gun about 1" away from the surface, on the high setting if you have options. On mine this is 1500W. You will begin to see the plastic darken to a shiny black, in a few seconds. Once it looks good move over to the next area before you melt/deform the plastic. It's not hard, just use common sense.
Here's a pic I took halfway through. Bad lighting, doesn't really do it justice. In person it's absolutely night and day. Just thought I'd share something that works!
Old 11-04-2015, 11:10 PM
bonus12
bonus12's Avatar
Easy trick! Now the question is how long it lasts. Better picture would be more reassuring but looks like a improvement.
Old 11-04-2015, 11:17 PM
porscharu
porscharu's Avatar
Have you ever cleaned the lens on your phone? The hazing/starburst effect on highlights like in your avatar pic indicates a dirty lens.
Old 11-05-2015, 12:06 AM
odonnell
odonnell's Avatar
The plastic itself actually melts on the surface, this is why the fading is "reset" or rather, the unfaded plastic below commingles with the faded part and it looks nicer. I accidentally touched it while it was still hot, and melted black plastic transferred to my finger so there's definitely something happening. (don't touch the melted plastic! It leaves a mark.) Jeep guys report it being a long term refresh, you're changing the structure at a molecular level and not just applying something like armor-all.
No kidding...I've cleaned it often (smartphone camera), I think my camera is on the way out. I clean it every week or so and even removing it from the case and cleaning it with a glasses cleaning cloth doesn't really help. Really annoying.
Old 11-05-2015, 01:19 AM
bonus12
bonus12's Avatar
Cool. Thanks, odonnell. I wonder if there's a more permanent fix for the rubber spoiler.
Old 11-05-2015, 08:45 AM
Noahs944
Noahs944's Avatar
Well done Mr. Odonnell. This is very timely, thank you.
Old 11-05-2015, 09:06 AM
jpk
jpk's Avatar
I would caution against trying the heat gun approach on any window trim or the spoiler while still installed on the car - the glass won't take kindly to localized intense heat...
Old 11-05-2015, 10:57 AM
dmjames
dmjames's Avatar
The glass doesn't really care that much, but I can say that the spoiler will *not* take kindly to the heat gun. I was using a heat gun to loosen the adhesive on some vintage purple window tint on my hatch and hit the spoiler with the heat a few times- it bubbles right up and stays a funky texture as a result.
Luckily (?) there's also a split in the rubber on my spoiler, so I was going to replace it anyway, otherwise I'd feel pretty stupid.
Old 11-05-2015, 11:03 AM
odonnell
odonnell's Avatar
Yeah for the spoiler it seems like the only thing you can really do is apply products to it, which of course don't last very long and need to reapplied. Whenever I wash my car I use a little trim restorer on it, and within a week it's back to how it was.
Old 11-05-2015, 12:10 PM
dmjames
dmjames's Avatar
Agreed. I've wondered if there's any kind of paint, dye, or other coating that would work on the rubber without a) looking stupid or b) cracking instantly and then looking stupid, but haven't had any luck.
Old 11-06-2015, 10:29 AM
konakat
konakat's Avatar
Has anyone tried plasti-dip on the spoiler? It seems like it would be a good option since it is rubberized and self-leveling.
Old 11-06-2015, 11:09 AM
lee101315
lee101315's Avatar
You can also use a can of black trim paint, it works great on restoring plastic and rubber!
Old 11-06-2015, 12:07 PM
Voith
Voith's Avatar
There is a product that is applied with sponge and it perfectly restores the plastic/rubber trim back to black. I used it on freelander trim (lots of plastic on freelander exterior) that was totally light gray. After half year it is still dark black.
EDIT:
Found it, this is it. 3M Bondo restore black
Amazon.com: Bondo 800 Black Restore - 8 fl. oz.: Automotive Amazon.com: Bondo 800 Black Restore - 8 fl. oz.: Automotive
http://www.xoutpost.com/bmw-sav-foru...pers-trim.html
Old 11-06-2015, 12:50 PM
dmjames
dmjames's Avatar
That looks like exactly the right thing to try... I'll have to see if I can find a bottle and give it a shot.
Old 11-07-2015, 07:49 PM
Tiger03447
Tiger03447's Avatar
There is a product called "Back to Black". I can't remember if itis a turtle wax product or Meguiars. I used Meguiars silicone purple stuff detailer on my spoiler..Looks great, but the car is not outside, either.
Quick Reply: 10 minute project: making black plastic look like new!
