Compression on a 968?
I had a PPI done on a 968 i'm thinking of buying. The shop that inspected the car said it had good compression all the way around at 135 Lbs. Not sure what measure is used to check compression. I tell my mechanic back in LA that compression is at 135 and he tells me its low. he tells my compression should be higher on 968s at around 175.
Its there two ways to measure compression, or is 135 low?
I believe the 968 compression ratio is 11:1, and I think one BAR is ~14.5. So that gives you ~160. Sounds like 175 is abit high, but since I've never done mine, I don't know what I'm talking about, so I can't say for sure what it should be. I've got the shop manuals at home, I'll see if it is listed there.
agent 325,
I had a compression test done when I bought mine last year - came out at 220psi for the #1 and #3 cylinders, and 215psi for the #2 and #4 cylinders.
Unfortunately, being a mechanical ignoramus I can't offer any insight into what these mean - but I was told at the time that this was a good result.
Good luck with your purchase - hope it works out.
My 86 944 has 9.5:1 compression [?] and had 162 psi across the board with 90k miles.
At 11:1 compression the 968 should have compression values above 185 psi, I think.
I would have another shop or mechanic do the compression test again. I haven't done the test myself but there can be significant differences with a hot/cold engine and doing the test with the throttle open/closed.
Good luck!
Bump;
Can someone help me out? From the numbers people are listing my logic is flawed somehow. I'm just curious as to what I'm missing. Thanks,
I think a lot has to do with how cold the engine is. If the air is being heated as well as compressed the pressure will spike up more (like with an engine that has warm heads as opposed to one that is dead cold.)
Gauges vary quite a bit too. I would not get worried if the numbers seem somewhat high or low, as long as they are pretty even.
-Joel.
-Joel.
