951 clutch replacement question
#32
no prob.
mytrplseven - the LR item should be called a 3-piece pipe. It has the 2-piece aspect of the 87+ pipe meaning the WG pipe can come off, but also it is split in the middle of the main pipe, so you could have access to the oil pan if needed.
#33
Ok, thanks for clarifying that. Now back to my original question: If I have a "two piece" crossover, does it allow me to remove the bell housing for a clutch job without taking the entire crossover off?
