Gates blue timing belt price
So I work full time at oreilys and I noticed we stock gates blue timing belts and I found out that I can order one for my car for 80$ with my discount and it said that I saved 45$ does that sound like a good price?
Seriously, the extra strength buys a safety margin that would let me rest easier at night. The extra money they cost is essentially lost in the noise of maintaining these things.
I'm new to the Porsche world, but far from new to swinging wrenches at cars. I can't say I'd ever pass up an opportunity to minimize the chance of a timing belt breaking on an interference type engine. A $60 difference in belt price is peanuts compared to the cost of replacing bent valves, punched pistons, etc...
Not busting your ***** at all, I genuinely want to know what the strongest and most durable option is for when the time comes for me to replace this one.
New pulleys are beter investment.
Blue belts fail too. Especially when toothed pulley seizes.
Why not both? Any belt will fail if a pulley siezes, but if you have that situation, belt longevity is not a concern since you probably have more serious issues. Again, not really a reason to opt for what is probably a part that wont last as long.
You're more than welcome to extend the maintenance schedule on your new-to-you 944, but most here (who've had them longer) will recommend against it. As someone who has had valves and pistons collide in my 944, I'll stick to the manufacturers schedule. Everytime I've pulled and replaced my belts, they've been fine (it was not a tb failure that caused my problem.) There was no major, discernable wear. I probably could have left them, but for $20 why risk it? $80 is another story. It wouldn't take long at that price to be more expensive than what I payed in head repairs.
I don't think anyone's suggested extending the time between belt/pulley/water pump changes. I certainly wouldn't. I would only suggest that a stronger belt provides a higher margin before failure than a weaker one. I have one of these Kevlar belts for the engine I'm building, but I'll change it and everything else on the regular interval. It's only $60.00 more, and it does contribute to the safe operation of the engine. People spend $1,500.00 on sport seats that do nothing regarding the integrity of the powertrain, so I'd say that $60.00 extra provides a lot of value.
Unless one is sticking strictly to OEM for purist/collector/concourse reasons, there is no reason not to use a more substantial part beyond cost. If an extra $60 every 30k is going to break the bank, old cars is probably not the best choice of hobbies.
If modern technology and manufacturing techniques can offer a better part, it makes sense to take advantage of that. Is anyone here running tires with a 30 year old formula for the rubber? Anyone running 30 year old formula for brake pad compound?
I guess my question has been answered. The only reason to run an original style belt is to save a few bucks. I'm ok with spending the extra for insurance though. Thanks for the responses.
Originally Posted by nihil
That's not a compelling reason to avoid getting what, in all likelihood, should be a stronger and longer lasting belt. That's just stating that the OEM belt works with the OEM maintenance schedule, which is known information.
If there are no underlying issues, the blue belt should offer no more safety than a regular belt. The OEM belt is really strong in a healthy environment so if you are looking for assurance I don't really see where it's coming from. I don't see any benefit to the blue belt unless you hope it would mask an underlying issue or simply extend service intervals. In any case, why not just eliminate underlying issues? You are thinking a pulley will seize and the blue belt will save the day?...or what scenario do you imagine?
The question really is, will a blue belt mask an underlying issue? And what are the odds?
On another note, I don't know for certain but in all likelihood Gates has implemented updated rubber and fiber tech into our OEM belts.
