NA-Tune in stock and available NOW!
Old 06-09-2016, 12:02 AM
CVR_Rally
CVR_Rally's Avatar
If only the 16v version was available.
Old 06-09-2016, 07:58 AM
harrisonrick
Captain Obvious
harrisonrick's Avatar
Where's the 16 valve version?
Old 06-09-2016, 09:17 AM
Noahs944
Noahs944's Avatar
Lindsay Racing - WELL DONE & thank you. This is the kit I wanted to buy but it wasn't avail so I bought another which was garbage. Will be in the market for an 8v and 16v in the near future.
Old 06-09-2016, 10:32 AM
Mike Lindsey
Basic Sponsor
Mike Lindsey's Avatar
Originally Posted by Arominus
A note for anyone that needs the 24 to 28 pin conversion, it is super mega easy. I did one for another lister and it was a quick job. If you can solder even a little bit and can read the instructions you will have no issues doing it yourself.
You're correct. It's not a hard job. A steady hand and the right equipment are what are needed. For a job like that, a soldering pencil with a pointed tip and not a soldering gun works best. 20 watts will do it. Anything hotter is not necessary and likely get you in trouble. Some thin .022" rosin-core solder works great. Probably $25-30 in equipment and materials.
Radio shack or Amazon is a good source.
We are happy to do the modification for you and so far have been able to return ship the same or next day from receipt in almost all cases.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
Old 06-09-2016, 10:35 AM
Rick Ryhal
Rick Ryhal's Avatar
Will this work with the 10.6 c/r euro engines? If so, what version would I purchase for a 1986 euro spec car? Thanks to all involved in this much needed project.
Old 06-09-2016, 10:42 AM
V2Rocket
Rainman
V2Rocket's Avatar
what is the best gas you can get over there?
the kit should plug and play with your car but the ignition timing is somewhat aggressive, and US 9.5 compression cars need premium gas to run the NA tune. so i would hope you have 93AKI or better for your higher CR.
Old 06-09-2016, 10:45 AM
Rick Ryhal
Rick Ryhal's Avatar
We are lucky to have 93 octane. I was wandering if the ignition maps would be aggressive enough for the higher compression pistons.
Old 06-09-2016, 10:53 AM
Mike Lindsey
Basic Sponsor
Don't congratulate us. We aren't doing anything special here. Joshua did all the hard work getting it to the point we can manufacture and supply it.
We built 35 of the longer lead time items and everything else can be pulled together quickly. Product availability should be immediate to no more than a week or two at any time. Right now there is adequate on the shelf stock for immediate dispatch. More are in the works. Enjoy!
Old 06-09-2016, 10:57 AM
Mike Lindsey
Basic Sponsor
We believe Joshua has been working on that. He will likely chime in and shed some light on his progress. We will be happy to build it like the other kits. We will have the A-Tune in stock next week. DME's in a couple more weeks. Maybe a 16v version soon.
Old 06-09-2016, 12:50 PM
drgon
drgon's Avatar
Aye, I'll be looking forward to the 16v version as well for my S when it becomes available.
Old 06-09-2016, 03:26 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
the kit should plug and play with your car but the ignition timing is somewhat aggressive, and US 9.5 compression cars need premium 91AKI gas to run the NA tune. so i would hope you have 93AKI or better for your higher CR.
On the 9.5cr cars there is some margin left in the timing tables...
A 10.6cr car would eat up all the margin. While you would probably be fine on 93octane, there really isn't any margin left.
I will adjust the tune to account for the higher CR cars, and give that to LR as an option.
Old 06-09-2016, 03:28 PM
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by harrisonrick
+1,000,000
The 16v is really close to being finished... However, I need a test car or two. The test car will also need to have a WBO2.
Old 06-09-2016, 08:56 PM
jimmerp
jimmerp's Avatar
How adaptable would the 16v maf system to mechanical engine changes? I am running a mild cam .
Old 06-10-2016, 10:07 AM
Rick Ryhal
Rick Ryhal's Avatar
Thank you Joshua. My only other question would be the O2 sensor or lack of one. Thanks again.
Old 06-10-2016, 02:19 PM
Arominus
Arominus's Avatar
Tom R has my old car, PM him.
Quick Reply: NA-Tune in stock and available NOW!
