Is there any reason why replacing the DME relay would smooth out the idle?
Old 02-20-2017, 02:33 AM
AkechiMotors
AkechiMotors's Avatar
Default Is there any reason why replacing the DME relay would smooth out the idle?
I had a bad vibration at idle which disappeared at 1500, and I was certain it was caused by bad motor mounts. I then replaced my DME relay with the Focus 9 solid state relay, and the vibration has just about disappeared. Coincidence? Why would that be the case?
Old 02-20-2017, 04:49 AM
H.F.B.
H.F.B.'s Avatar
Did you change back to the old relay and the vibration came back. So could you reproduce the effect this way?
Old 02-20-2017, 10:44 AM
V2Rocket
Rainman
V2Rocket's Avatar
Only thing I can think of is the old relay was giving an unstable power source to the DME?
Old 02-20-2017, 08:03 PM
944Ross
944Ross's Avatar
Mine seemed to run smoother too, after installing the SS DME. Maybe the relay was chattering?
Old 02-21-2017, 10:34 AM
AkechiMotors
I didn't - I'm afraid that whatever happened won't happen again if I swap them back, and I'll be back to replacing the motor mounts
Quick Reply: Is there any reason why replacing the DME relay would smooth out the idle?
