Manual Steering Rack Tie Rods
Old 05-26-2017, 02:03 PM
4score4
4score4's Avatar
Default Manual Steering Rack Tie Rods
While replacing my strut inserts I saw that my old male tie rod ends long gone. I have to change the inner rods too, which are most likely just as old anyway. Anyone have experience with deutschepartsusa? Besides old OEM stock ($$$) these are the only reproductions I have found that look like they have the rubber insulated section and are reasonably priced. Specifically http://www.ebay.com/itm/Porsche-944-...vuDR5A&vxp=mtr.
1984 - 944
Thanks,
old leaky male end
manual female tie rod
Old 05-26-2017, 02:27 PM
Severian
Severian's Avatar
I don't have any experience with deutschepartsusa, but I only have good things to say about 944online.
http://www.ebay.com/itm/PORSCHE-924-...QAAOxyPc5R-WiR
I swapped out my power steering rack for a manual rack about a year ago with the tie rod assembly from 944online and it's still solid to this day.
Old 05-26-2017, 11:25 PM
snb13
snb13's Avatar
Agree. Go with 944online.
Old 05-26-2017, 11:47 PM
V2Rocket
Rainman
V2Rocket's Avatar
..or you can use the direct-fitting 1992 VW Jetta parts and avoid the "944online tax"...
get the manual steering parts.
http://www.rockauto.com/en/catalog/v...e+rod+end,7428
Old 05-30-2017, 04:43 AM
951Dreams
951Dreams's Avatar
While you can't really go wrong with 944online, I have to agree that sometimes they are a little steep. The trade off is, Ian and Steve know their stuff on these cars, and if there is any questions (and there often can be on these cars) they will make sure you get the right part. Plus there is just something cool about buying Germans parts from a guy with an English accent! LOL Plus I LOVE the kits they put together!
I'm going to have to file that Jetta info into the "good to know when the time comes" category.
Old 05-30-2017, 10:47 AM
jsheiry
jsheiry's Avatar
Spencer
Is there an 87 up similar tie rod end for when you are putting the manual rack on an 87 up car like 968?
John
Old 05-30-2017, 11:48 AM
Voith
Voith's Avatar
For late offset & manual rack you need these:
Got the moog tie rods today They are dirt cheap, 11€/peace.
The long moog number is VO-AX-7181, the other VW number for this part is TA1283
Manual rack bellows/boot alternative numbers are Seinsa D9014 and D9090
And these:
Lockheed - Delphi TA770, also ,BMW : 3211 1116 463, Volvo : 3211955 - 3265974 ,Volkswagen : 171 419 812
Bottom one on this picture is 89 power steering
Kurt R (05-20-2023)
Old 06-06-2017, 11:57 AM
4score4
4score4's Avatar
Hey V2Rocket,
Your option is great for saving some cash! Would I go with the wonky ends of the jetta too? Or would I need to get theses:
http://www.rockauto.com/en/catalog/p...e+rod+end,7428
Old 06-06-2017, 12:41 PM
MAGK944
MAGK944's Avatar
Originally Posted by 4score4
...wonky ends...
dofl, sorry, carry on....
Old 06-06-2017, 12:42 PM
V2Rocket
Rainman
V2Rocket's Avatar
reminds me of one time a guy was describing his custom 951 intake manifold and they were going to use velocity stacks "bell mouths" with 100mm length but he kept on writing "100mm bell ends"
Old 06-06-2017, 12:46 PM
odonnell
odonnell's Avatar
Another question is, what's the deal with tie rod end thread. It looks like the Jetta manual inner rods are male ended and so are the 944 outer tie rod ends. So I guess use the Jetta tie rod ends too? It looks like the power/manual steering rod ends are the same. Is that correct?
Old 06-06-2017, 01:30 PM
4score4
4score4's Avatar
odonnell,
Right, new tie rods have male outer thread. My current 944 ends have male thread. Which means I can't get a totally "correct" setup. My thought was I could get 944 power steering ends that do not have the bend in the tie rod end like the Jetta's. It would then look close to 944 Online's setup. Female ends, male inners (with the female connection to the rack). I think the bend in the Jettas rod could make the alignment/installation harder.
Old 06-06-2017, 02:57 PM
odonnell
odonnell's Avatar
It looks like the main difference between the manual and power 944 rod ends is the male vs female thread on them. So yeah, that should work.
Quick Reply: Manual Steering Rack Tie Rods
